What's Typical Machine Work Cost to Fresh a Stock LS1?
I'm calling around trying to see what's normal to freshen up my 145k mile stock shortblock.
Basic things:
-Disassembly of the shortblock
-Clean the block
-Inspect the crank journals, lifter bores, mains, cylinder roundness, rods, and pistons/skirts
-Hone the cylinders for new rings
-Install new cam/rod/main bearings (oversize/std dependent on how the inspection goes)
-Cleanup of the deck block surface with mill (if needed)
-Reassembly w/blueprinting of tolerances
What's the average cost?
Block cleaned
Decks checked
Very light cylinder hone
File fit piston rings
Line hone main caps
Replaced cam bearings
Assembled short block with cam and timing chain.
The cam bearings were included in the $750, I provided the main studs, crank, rods, pistons, piston rings, main and rod bearings.
Also my rotating assembley was ballanced at texas speed when I bought my crank.
Cleaning
Overbore and hone
Line bore mains
Equalize decks
Hone lifter bores
Cam bearings installed
Main bearings in a box
ARP main studs installed during line bore
I paid more to have the decks equalized, otherwise they just cut the same amount off each and one can still be higher than the other. Machine work on an LS won't be much different.
If you want them to assemble the short block, and make all the measurements, and machine to fit, and balance, I bet you will be up between $2000 and $2500. There is alot of time involved if it's not just slapped together, and shop rates for people who know what they are doing aren't cheap.
So that $2000-2500 seems pretty accurate.
Line Hone mains and cam bore
New cam bearings installed
Decked Block
Bored/hone with torque plates to 3.903
Balanced entire rotating assembly, supplied by me
Clean and pressure test block
File fit the rings to each cylinder
Used all ARP hardware supplied by me for the machining.
Do not deck the block if at all possible. Pistons come out of the hole .007-.008 from the factory, deck the head and let the headgasket do the rest. I usually check the block for flatness, and even on some that have had headgasket failure there was only .003" worth of warpage
I am in the same boat once again, need new rings, maybe pistons again. I have been eyeing, Thompson Motorsports as the prices are pretty darn good.
If I'm looking at $1200 for new bearings + machine cost/blueprint/assembly + the cost of the forged rotating assembly, then yes, it's worth it to look at it that way. Then I'm getting close to just dropping a 408 or something in there ha.
And down the road I'm doing a supercharger. A 347 would be fine with a supercharger.
Spending thousands upon thousands MORE... I want more than another 40HP. I want like another 250.
Spend an extra couple hundred on a smaller blower pulley, and tuning. That will be 50-80 hp additional for a few hundred bucks.
And if I do the supercharger route, I'll have too much compression. But it's easier to change heads than rebuild the shortblock.
Also, I haven't ruled out just hitting it with nitrous. Either way, the 347 would be fine.
Blueprint tolerances
Hot tank and pressure test block
Check lifter bores and hone if needed
Deck Block
Honed with torque plates to 3.905"
Polish and inspect stock crank
Assemble shortblock
That's in the $1300 range from both of them.
I just supply the pistons, rings, rods, and main/rod bearings.
