I need to replace both CATS - california smog, I live in Texas
The CA sticker means the car was built with the extra restrictive 50-state cats. You can take those off and put on a 49 state cat with no effect on the car other than an increase in power.
I live in CA with a 49 state car and had no problem with the sniffer test.... lol
I should pull the sticker, then try another shop, and proceed like originally planned, putting in some universal cats, and expect no problems???
Who said you need the cats?? Just weld in some straight pipes and call it a day. Should only cost you a bit more than $100 in change at a good exhaust shop out there.
![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Does anyone know someone in the area who would be willing to NOT look at my ^&*$@#$ California Emissions sticker, and weld up some decent cats? I keep getting the same question, why am I just not getting straight thru pipes and what not.. I want to pass smog... and be legit. BUT not have to pay the $%^&*@# California Tax to do it...
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Why do I have to pay out the nose just to repair my exhaust on my Texas Registered WS6?? If I do NOT have to pay through the nose, why do I have to break the rules, or jump thru hoops? I have a bad inspection sticker, and I just paid this motherf_cker off... damn man...
#33
I don't even know why this is even a debate. Bottom line, his car was manufactured to be California compliant. Believe it or not, it's true. I had a 2010 Dodge Ram that had a sticker that said it was NOT California emission compliant! The technician at the Texas repair shop is right. By law, he needs to install the "correct" cats. I had someone at work who had to replace their cats here in California because of the same part # problem. The old ones sniffed cleaner too, but the law is the law.
#36
the vehicle must inspected as per the laws the said vehicle is registered in. for example you live in houston and the vehicle is registered in harris county the vehicle must pass the emissions and safety portion but non smog regulated counties such as waller county only need a safety sticker. now if you just get a non catted y pipe and get the car tuned and go to get your emission/safety inspection done you should pass as long as the computer doesnt have any codes and the readiness monitors are all set you should pass.
#37
Each state has it's own regulations, and in order to pass inspection and get a sticker in that state you need to pass those. Not some other state's.
Where in a legal document does it state that a TX registered car has to adhere to CA regulations and SMOG because it was once built for and registered in CA?
#38
Wow...
Took the car to a shop today, and spent 450.00 in labor. Purchased a great set of used cats from a forum member, he even delivered them to me, brought a techII, BS'ed with me for a few hours, and his girlfriend was patient the whole time!!
I tried myself with 3 cans of PB blaster, over the course of 3 days.. I said **** it, and had a shop do it.. 4 broken studs laster, and $$$, the new cats are on, AIR tube has been removed and cleaned and replaced, DTC's cleared, now I am driving looking for readiness..
Hoping to get that sticker tomorrow.. and get that Magnaflow Cat -back welded up, all in time for my drive in to work Friday..
#39
It may be true, but as others have said...regardless of where it was manufactured to be compliant to, right now as it stands it only has to adhere to the regulations of the state it is registered in.
#40
Wow...
Hoping to get that sticker tomorrow.. and get that Magnaflow Cat -back welded up, all in time for my drive in to work Friday..![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
( with the cats removed those broken studs are easy to extract/retread/replace )
The MagnaFlow catback does not require any welding, it bolts in.
