How high will it rev?
Old Oct 19, 2013 | 02:57 PM
AndersonsSS01's Avatar
Originally Posted by Martin@Tick
A Fast 102 intake has a smaller runner entry than a stock OEM intake. This is why they boost mid-range torque so well. If you look at the white Z06 in the Tick cam thread in this section his peaks at 6500rpm and hasn't begun to even roll over yet.
If the OP ends up using an OEM intake I'd shift it at 7000rpm, but if he goes with an aftermarket plastic OEM 'style' intake he may be better off shifting at 6800rpm.
Yes i am using an OEM ls6 intake so it looks like i will be shifting at 7000 as long as like i said in the original post you guys think my bottom end will be alright, which sounds like i should be fine from the way you guys are talking.
Old Oct 19, 2013 | 03:18 PM
td1168's Avatar
The 92 does a pretty good job as well. In fact I feel the 92 does a better job at this IMO, but I have not tested either intake back to back or even on the same car to see any type of truth to this.
That said, the combo's we do with Fast 92's versus identical combo's with Fast 102's, the 92's seem to make more power.
This is music to my ears! Being that I just installed a fast 92!
Old Oct 19, 2013 | 03:30 PM
td1168's Avatar
If you're gonna shift at 7k then have your rev limiter set at 7200 so your not bouncing off of it when you shift. Also, these aluminum blocks aren't very forgiving of steel connecting rods flying loosely around in them! Good luck.
Old Oct 19, 2013 | 06:40 PM
inssanity21's Avatar
Well that makes me feel a little better then!
