Tips needed for Comp Check and leak down
Should the Car be warm? Which should I do first? If I have good compression do I have to do the Leak down.
to do the leakdown test:
1.warm up car
2.pull all spark plugs
3.loosen the rockers (gotta have the valves shut)
4.hook up leakdown guage to air compressor
5.screw air hose into a cylinder
6.connect guage to air hose in motor (make sure you have the motor locked up and the e-brake on)
7.check PSI on both guages and find the percentage leakage
8.move on to the next cylinder
if one of the cylinders is losing a lot of pressure, you'll be able to hear where it is escaping. into the intake is a bad seal with the intake valve (maybe bent), into the exhaust is a bad exhaust valve seal (maybe bent), or into the crankcase is a bad ring or piston.
good luck to you
8 out of 8 plugs had a dark band on the ceramic, 6 out of 8 had burnt through the ceramic in the same band. Nothing like an engine that burns 3 quarts of oil/1000 miles.
