Can anybody tell me what compression this setup would give me
I think MTI allows you to choose between a couple different compression ratios. If the heads are not decked the compression will stay factory stock at 10.3 with 67cc combustion chamber. You have to change the combustion chamber volume or the pistons in order to change the compression. Hope this helps
MTI Ported LS1 Stage 1 Heads
LS6 intake manifold
MTI X1 Cam (230/227)
Ported and Powdercoated Throttle Body By Bauer
Underdrive Pulleys
What kind of rwhp and compression am I looking at here...anything else I should add/remove? Thanks in advance, I really appreciate it!!
LS6 intake manifold
Underdrive Pulleys
