SDPC balancer bolt
Old Oct 19, 2013 | 03:27 PM
ezzlez28's Avatar
Default SDPC balancer bolt
I'm in the middle of my heads/cam swap, can't find an answer on the sdpc balancer bolt torque spec. P/n SD6621. Appreciate any help I can get. I sent a pm to them but haven't heard back yet.
Old Oct 19, 2013 | 04:31 PM
ls1 1990 VN's Avatar
http://www.ls1howto.com/index.php?category=1 This should help you with all the torque specs
Old Oct 19, 2013 | 04:42 PM
WS.SIX's Avatar
He'd probably end up snapping that bolt or ripping the threads out the crank if he followed that. SDPC isn't a TTY bolt.
Old Oct 19, 2013 | 04:51 PM
ezzlez28's Avatar
Correct, it's not tty. To be honest, it looks 100% identical to the arp bolt, made from the same grade chromoly, so I imagine it'll be similar. Just was hoping to not do any guess work on something like this.
Old Oct 19, 2013 | 05:21 PM
235 ft/lb with moly lube. No stretching procedures.
