Lunati forged rods? help please
Old Oct 24, 2013 | 04:06 PM
stang_kllr's Avatar
Default Lunati forged rods? help please
I picked up a 383 short block a while back. I was told it was a lunati forged rotating assembly. long story short, I sent heads off to AI and got a custom grind cam, and also im doing the bearings. I got the mains on, and now onto the pistons. But I wanted to make sure on the torque specs for these rod bolts. I called lunati and since there are no part numbers on the rod, its a little confusing.
from the way I described the rods, the tech believes they are billet I beam rods and use a arp 2000 bolt on them and require 73'lbs with arp moly lube. I just want to be sure I get this put together right. come someone, based off these pictures, verify the rods I have pictured? thank you
Old Oct 24, 2013 | 07:54 PM
stang_kllr's Avatar
anyone?
