new heads for ls6 for driftpower!
Old Nov 9, 2013 | 01:36 PM
Johnny_k's Avatar
Originally Posted by 2muchboostNY
Couple of my buddies with LS1's and LS2's in Nissan chassis who drift religiously use a dual pass radiator such as AFCO, Mishimoto, or Griffin, add a low temp thermostat, a good oil cooler, good fans, and some body ducting (to channel air over the radiator portion). These guys will drive an hour or so to the track, beat their cars silly, drive home an hour and never have an issue relating to cooling. A few have added water/meth spray just to increase their cooling capabilities but most havent and havent had any issues thus far.
As far as the heads, I am too much of a noob to offer any advice.
Good info right here
Subscribe for more info
Old Nov 14, 2013 | 10:35 AM
larsieboy's Avatar
Here is a picture of the exhaust..
Old Nov 15, 2013 | 04:52 PM
larsieboy's Avatar
Brian tooley made me a nice offer!
He recommends a cam with the following specs.
231/240 .598"/.588" 112+3 HUC/Ext RPM
what do you guys think?
Old Nov 15, 2013 | 05:23 PM
427zm's Avatar
If Tooley recommends it, I'd listen.
My friend just had Tooley recommend an almost identical cam to use with a set of TFS as cast 220's, w/ powdered metal guides and turned down LS3 valves. Great setup!
Old Nov 15, 2013 | 06:30 PM
LilJayV10's Avatar
Yup. If Tooley recommends it, it's gold.
Old May 9, 2014 | 02:53 PM
larsieboy's Avatar
Dear friends.
I gathered all the parts from tooley. Great guy!
-220 as cast (59cc)
-fast102 intake manifold
- 231/240cam
etc etc
Now the problem. My engine builder rejected my ls6 engine. The engine suffered from overheating and bad quality control from gm and who knows what. There were chips from the pistons missing and from the right bank the hone grooves are gone. The crate engine was also bored out of the center so there is no more space to rehone it :-(
What would be a good plan now. Can i use the stuff i bought on a new ls2 stroker shortblock? or a better plan?
thanks
Old May 9, 2014 | 05:25 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Get it sleeved? Steve at RED will do actuall 1168 LS6 blocks
Old May 9, 2014 | 09:44 PM
427zm's Avatar
Originally Posted by larsieboy
Dear friends.
-220 as cast (59cc)
- 231/240cam
etc etc
thanks
I talked to Steve at RED about resleeving my LS6 when I was researching for my current build, and from what he said, it's pricey to sleeve the LS1/6 due to the MID Sleeves. I believe he quoted me off the cuff near or possibly over 2k for the resleeving only.
I'd say, your best move is a new block. Your top end setup will be legit on any LS1/2/6 you out it on!
Old May 11, 2014 | 05:19 PM
larsieboy's Avatar
resleeving is really expensive here in europe. So probably is going to be a new shortblock.
do these heads also fit an ls3 shortblock? and what about the oil/waterpump?
