Checked piston to valve clearance. Having issues
how thick should the clay be? that was another issue i had. my first try i had too much clay and it wasent even able to sit flush. then, after fixing that when i finally ran the test the valve cut through the clay and took some of it with it into the runners. how can i avoid this because its makes it pointless if it takes the clay off the cylinder when u remove the head.
So I checked it again this time at zero lash instead of 22ft lbs and I got about .150 on exhaust side. Intake side got messed up I guess I put too much clay since it grabbed the valve and pulled it down.
Yeah I may look into that to make sure. I checked the intake side again and got .095".
Assuming these measurements are right, if I would to mill the heads the clearance would be lessened by the same amount that was milled, correct?
Yeah, i thought if the cam was ground incorrectly i could have issues, but i doubt it could be off by that much since its a comp cam, and I would hope those guys do good work. the part number is 54-438-11 and grind number is XR281HR,
this may be a dumb question but when its dot to dot it should also be top dead center correct? shouldent the cam be on the base circle of both intake and exhaust at that point, because it looks like its about to open the two.
My cam is bigger then the above and clears 40 milled heads. I agree though, the dial indicator method is much better.
Yeah its funny how things turn out since i originally thought I was going to be in the clear based on your experience. but it looks like I am anyway.
What were the specs of your cam and what heads do u have on?
and how did u measure and how much clearance did u end up with. it still doesent seem right to me that I have .095" on intake and .150" on exhaust, and thats on the unmilled 243 head. I am thinking it can still be due to the fact that the LS6 has the longer valves because at zero lash i think it should increase it by as much as that extra length.
Ill check again with the .030 milled heads.
I checked my 799s before I sent them off. I mocked them up with an old head gasket, two correct length pushrods, two checker springs from Comp, and a dial indicator. As you roll the engine around you blip the valves down (by hand) at intervals until they hit the piston. You watch the dial indicator while you're doing it. Obviously on the intake valve it will chase the piston down (less clearance is acceptable here) and on the exhaust side the piston will chase the valve up (valve control and clearance is crucial here). You'll find your closest measurements at these two points. Once I established my clearances I discussed it with A.I. and we determined another 30 to be safe. So that's what I went with. I did not recheck during final assembly.
#32
I have been looking to sending the heads to either AI or TEA. but with TEA, the larger valve could cause and issue but when I spoke to them they said if I clear it now then I should be fine.
When i calculated what the 2.04" diameter valve compared to the stock 2.00", decrease of PTV clearance I got .0052". this comes from the fact that the stock valve angle is 15°. so you take the difference in diameter, .040, which results in an increase of radius of .020"
then you do .020"(sin15°) = .0052".
is this correct?
is this correct?
