How much can i MILL
Old Nov 21, 2013 | 06:24 PM
MIKELMOTORCYCLE3398's Avatar
Default How much can i MILL
I need your EXPERIENCED opinion on this and not "upgrade your cam blah blah".
How much can I mill my 317's? Goin on a stock bottom end 00' 5.3L with a gm hotcam on .550 lift 219/228 .550/.550 112lsa. Keeping stock valve size. Do u think .030 off will be ok without PTV issues?
Old Nov 21, 2013 | 08:45 PM
bowtieboySS427's Avatar
I think you'll be absolutely fine. But always measure. I think somewhere around .050-.060 you'll have intake alignment issues. I'm betting with that cam installed right will be no problem.
Old Nov 21, 2013 | 08:53 PM
A.R. Shale Targa's Avatar
how bout change your heads...LOL; you'll likely have to mill them 70-80
thousandths just to restore the factory 9.5 compression ratio or are you
intentionally trying to lower it for a turbo application ????
Old Nov 21, 2013 | 09:06 PM
And the Hot cam is .525/.525 on lift unless you got something different than what I have
Old Nov 22, 2013 | 09:51 AM
I got it ground to .550 lift when i had it made, and yes a FI application is in its future.
Old Nov 22, 2013 | 09:52 AM
Thanks guys
Old Nov 22, 2013 | 02:00 PM
PREDATOR-Z's Avatar
Lift at .050 has nothing to do with PTV clearance.
Old Nov 22, 2013 | 02:04 PM
erickcastillo95's Avatar
i think you should be good with 30 over i have a friend running 317s milled 30 over on an lq4 with a 228r cam and there is no ptv issues
Old Nov 23, 2013 | 12:16 AM
01ssreda4's Avatar
What compression are you trying to maintain. I guess I don't follow the how much can I mill but i need to keep compression low for FI later.....What are you trying to accomplish?
Old Nov 23, 2013 | 01:00 PM
96capricemgr's Avatar
Well then it isn't a GM Hotcam is it?
WTF is "30 over" when discussing heads?
Hard to help people when the OP and half the respondents are clueless.
Old Nov 24, 2013 | 09:18 PM
Mike_hawk's Avatar
I have an lq4 with a tsp 224 cam, I had my 317's milled .040" and used a stock gasket. The compression calculator I used put this combo at 10.2 to 1.
