Spun cam bearings soon after bearing change - myth or not?
That clearance is within spec, I'd run it depending on how deep the scratch is. You can also take some 2000# sandpaper and smooth out the scrtch.
If you do swap the bearings, I recommend getting the right tool and also measuring the clearance after installation.
For some reason it seems all are. It's been discussed a lot. I remember seeing several threads with engines with low miles from the factory look really bad.
Cam bearings can be a pain and easy to screw up if you've never done them before. It's easy to get one cocked.
One some engines the cam bearings are different sizes and must be installed into the corresponding hole.
It's a good idea to put a slight chamber on the bearing to ensure there are no rough spots on the edges and helps in the installation process.
As mentioned you can clean them up with a fine scotch brite pad or sander paper afterwards to ensure they are smooth.
