CI Displacement Forumla????
Old May 7, 2004 | 02:40 PM
Mike TexaSS's Avatar
8 Sec Tuner
Default CI Displacement Forumla????
Can someone post it?
Old May 7, 2004 | 02:44 PM
ddelallata's Avatar
this is not perfect, but here goes: ___Litre X 61.15 =_____ cubic inches
Again this is not perfect but it will give you a ball park figure
Old May 7, 2004 | 02:47 PM
DenzSS's Avatar
π x (radius)2 x stroke x number of cylinders
Old May 7, 2004 | 03:19 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Usually I use this one for quick calculations although its the same thing in different order:
bore x bore x stroke x pi / 4 x 8cyl
Old May 7, 2004 | 04:04 PM
badls1's Avatar
http://www.rosspistons.com/calculator.php
Old May 8, 2004 | 01:20 AM
99huggerorangeZ's Avatar
http://www.smokemup.com/auto_math/index.php
Old May 8, 2004 | 06:50 AM
hondakiller's Avatar
i always used bore x bore x stroke x .7854 x number of cylinders, what joseph said except .7854 is pi/4
Old May 8, 2004 | 10:52 PM
smokemup's Avatar
Displacement Calc
Formula is:
All units are inches.
Cylinder Area = PI * (Bore / 2)^2
Cylinder Volume = Cylinder Area * Stroke
cuin displacement = cylinder volume * number of cylinders.
Old May 9, 2004 | 12:58 AM
blackz93's Avatar
radius squared x stroke x pi(3.1416) x 8 = cubic inches...
Old May 9, 2004 | 03:48 PM
Ben R's Avatar
bore x bore x stroke x # of cylinders x .7854
Old May 9, 2004 | 10:31 PM
427's Avatar
427
bore x bore x stroke x 6.2832 = ci v8
Kurt
Old May 10, 2004 | 07:33 AM
Old SStroker's Avatar
Yep. Notice that 7854 are the numbers in the upper left corner of a calculator keypad. No need to remember them, just start in the upper left corner and go clockwise.
