317 heads
Old Nov 26, 2013 | 10:06 AM
bones5133's Avatar
Default 317 heads
I have a set of 6.0L 317 heads.
Had a machine shop shave .030 off the heads
they said they pressure test the heads and had to grind the exhaust valves (they put a performance cut)
I had them install Brian Tooley racing springs as well.
My bill is $400.00 is this about right?
Old Nov 26, 2013 | 10:09 AM
KCS's Avatar
KCS
Moderator
Define "grind the valves". Did they actually grind the valves and/or cut a valve job?
Old Nov 26, 2013 | 10:10 AM
bones5133's Avatar
No they just cleaned them up.
Old Nov 26, 2013 | 10:28 AM
IllusionalTA's Avatar
refaced the valves.. typical.. seems a bit high... i just had .040 removed on a set, and the chamber cc'd it was 190.00..
Old Nov 26, 2013 | 10:47 AM
bones5133's Avatar
I was thinking this was High. I haven't picked the heads up yet but want to know what questions I should ask why the bill is so high?
Old Nov 26, 2013 | 11:17 AM
wildcamaro's Avatar
Yea that's a but high, should have got a complete valve job for that price since 400 is halfway to a Cnc port and valve job
Old Nov 26, 2013 | 12:29 PM
he should give you a price breakdown of what he did.. tough deal after work has been completed.. Youre pretty much stuck w/ payin it..
Old Nov 26, 2013 | 02:21 PM
sleeperlqx's Avatar
my shop charges 40$ per head any amount milled that you want....
and 20$ to install my Brian Tooley Springs...
therefore Im looking at 100$
you my friend got suckered.
Did he supply the springs as well?
if so, then 150$ was for their labor, not too far off.
Old Nov 26, 2013 | 02:27 PM
Burken01's Avatar
Did they bead blast/clean the heads?
Some shops add this in especially if its a dirty head, without you realizing!
Did they give you an estimate at all? Usually they stick real close to that and won't do any extras without callin you first to ok it..
Old Nov 26, 2013 | 10:02 PM
bones5133's Avatar
Ok I feel a little better now.
I picked my heads up and when I authorized them to clean up the valves I guess a miss communication and they did a complete valve job on the motor. With a 5 angle cut this was 195.00 of the $389.00
Old Nov 27, 2013 | 07:36 AM
ironmanLS1's Avatar
That's about what I pay for a valve job. By looking at your other post on the BTR springs it sounds like this is a good shop that does not just slap things together and rather checks, inspects, and measures. That total bill is not out of line.
Old Nov 27, 2013 | 09:02 AM
KCS's Avatar
KCS
Moderator
That's more like it. Fair price for the valve job included as well.
Old Nov 27, 2013 | 01:36 PM
20.00? Do they measure anything? Or just slap em on..?
