Oil pressure question
Old Nov 27, 2013 | 06:27 PM
Possum Boggs's Avatar
Default Oil pressure question
I just did a 228R cam swap in my 120k mile ls1 with a ls6 ported pump and its holding about 40lbs under acceleration and around 25 at idle is this typical it's a 99 ls1
heres a link to a video
https://www.facebook.com/photo.php?v...43361096115087
Old Nov 27, 2013 | 06:31 PM
fruitsalad's Avatar
Did you put in the new oil pump during the cam install? If so, you may have torn the o-ring putting the pickup tube back on. Some people will say that pressure is fine, and theoretically it is, but I wouldn't call it exactly normal.
Old Nov 27, 2013 | 06:40 PM
yea,thats when i put the ls6 in,i had the pan off and everything its went on perfectly i cant see it being torn
Old Nov 27, 2013 | 06:59 PM
fruitsalad's Avatar
And this only started after you did the cam swap?
Old Nov 27, 2013 | 07:09 PM
its about the same pressure it had before i figured there would be more with the ls6 ported
Old Nov 27, 2013 | 09:36 PM
Superslow0288's Avatar
If the pump is only ported it won't increase pressure, it would need to be ported and shimmed. Aka blueprinted lol you blueprint a house not a pump...anyway porting only increases volume not pressure...IMO if that's the same pressure you had before then it is what it is...should be fine these motors have never been known for amazing oil pressure. What weight oil you running?
Old Nov 27, 2013 | 10:29 PM
10w 30 penzoil,every ls1 ive had never carried the same pressure lol this is my 7th one!
Old Nov 27, 2013 | 10:41 PM
blackbirdls1's Avatar
This makes me want this cam even more
Old Nov 27, 2013 | 10:47 PM
i dont see the cam making this happen
Old Nov 27, 2013 | 11:21 PM
fruitsalad's Avatar
If you're seeing the same pressure as you were before the install then I doubt anything went wrong while camming it. I don't see the cam being an issue at all in this either, and it couldn't be the oil pump if you've changed oil pumps without seeing a change in pressure.
I'd say carry on and maybe even hook up a mechanical gauge to see if it's your sending unit or electronic gauge dying, which is possible.
Old Nov 28, 2013 | 07:30 AM
LS1MCSS's Avatar
With 6 others that had about the same pressure, I don't even see the reason for questioning it. Drive it you stole it.
Old Nov 28, 2013 | 08:23 AM
Fastdriver1992's Avatar
i've seen worse survive. my fathers car has about 15psi at idle (bearings were left alittle lose on the build) but once he's over 2000rpms its over 40. rule of thumb is 10psi per 1000rpm increase.
i've seen STOCK ls1 cars idle as low as 18psi. its all about how quickly the pressure rises with rpm that matters
if its been this way since you bought it, i wouldn't even be concerned
*** on a side note, is your temp gauge broken? i see its stone cold. not good reving the car like that cold. and as the car warms up the oil pressure will only get worse as the oil gets hot and thins out
Old Nov 28, 2013 | 12:19 PM
The temp gauge wasn't plugged it,I have a 99 motor and idk why but the cars a 98 and the plug in for the temp sensor was different
Old Nov 28, 2013 | 01:24 PM
01ssreda4's Avatar
To me that's on the low side but acceptable.
