Bad knocking on cold start up.
Old Dec 28, 2013 | 06:37 PM
  #41
bigtodd's Avatar
It broke a rod, now to pull the engine and see if a rod and piston can fix it.
Old Dec 28, 2013 | 11:58 PM
  #42
cosbysweater's Avatar
In my ls1 I had a rod snap at the base at the top of the stroke, luckily nothing was damaged good luck to you and I hope you have the same luck I did
Old Dec 29, 2013 | 01:51 AM
  #43
LilJayV10's Avatar
Originally Posted by RockinWs6
That's not a rod bearing noise.....prolly broke a rocker....geez what is this just toss out anything when you don't know thread?
Yeah. It kinda seems that way....
Old Dec 29, 2013 | 08:12 AM
  #44
KevinR's Avatar
Wow prolly a broken piston, rain water leaks past the windshield cowling and runs down on top of the intake manifold. The intake is loose and the water leaks past the seals and into the engine. As you start you slug a cylinder with water and it hydro locks breaking the piston-rod etc. Good Luck.
I knew it wasn't a bearing.....
Just like you "knew" it wasn't rod noise. Oh, and how you knew it was cam related. And let's not forget how you knew it was valve train noise. Correct??? Nice job. You helped out a lot.
Old Dec 29, 2013 | 01:12 PM
  #45
RockinWs6's Avatar
Geez I tell ya its not rod bearing noise and i'm right.........hmmm
Sorry next time i'll join you guys in the ITS ROD BEARING NOISE standard BS.
It broke a rod not a rocker, that why it didn't run properly.
If it was a "ROD BEARING" It would have run fine and just knocked....
You guys are so smart.................
Old Dec 29, 2013 | 01:27 PM
  #46
redbird555's Avatar
well it was rod noise in that thread..........this aint. Its cam related.
Rod bearing wouldn't make it run like it is, something else is going on. Broken rocker valve pushrod lifter etc.
yupppp because you obviously knew it was top end related lol at least we all guessed bottom end
Old Dec 29, 2013 | 02:33 PM
  #47
bigtodd's Avatar
I appreciate all the input I can get, thanks everyone.
Old Jan 7, 2014 | 08:47 AM
  #48
99wssixm6's Avatar
Nice.....
Any pictures for us to admire?
Old Jan 8, 2014 | 08:21 AM
  #49
MadFirehawk86's Avatar
I have an 01 Camaro Z28 that sat up for 3 yrs fixed her all up and drove several miles to make sure everything was ok...no knocks no abnormal noises or anything. Parked it and came out the next day to show her more love and this same exact noise occurred on start up. I was cringing the whole time and it ran like complete crap...just like in the video.
Here is what fixed it...gave it a few revs and it went away and the car instantly ran smooth once the tap stopped. To this day after 600 miles it hasnt tapped or ran erratically. I chalked it up to a lifter that wouldnt pump up or was stuck since the car sat for so long.
Old Jan 8, 2014 | 09:43 AM
  #50
Burken01's Avatar
Did you clean that 3 yr old gas outta the tank before startup?
Old Jan 8, 2014 | 10:17 AM
  #51
Yep, had to replace the fuel pump so the bad gas was dealt with. Changed the fuel filter as well.
Old Jan 8, 2014 | 10:30 AM
  #52
Burken01's Avatar
Did you clean out the old gas in the main fuel line, that's some of the most potent stuff I've ever smelled lol
Old Jan 8, 2014 | 10:41 AM
  #53
Yea I had my wife key on and key off the ignition while I held the shrader valve open with a allen wrench until I got clean fuel. That fuel was terrible I thought for sure Id have an injector or two go bad, but the car runs perfect and pulls hard just like before.
