Piston rings or valve seals?
Motor smokes ALOT when i accelerate hard. It does that only at high rpms. However, i think this is not from the engine but rather from the oil filled exhaust system.
My previous engine had a couple of really bad piston rings. Oil used to literally drip from the exhaust and i used to put a quart everyday. Drove it like that for about 3 months. So now i figure when i rev the engine hard, the heat is burning the oil in the muffler/exhaust system, hence the blue smoke. To be sure, i disconnected the exhaust pipe at the headers and reved the engine a few times...no smoke at all.
However, after the above test, i did a compression test. When i pulled out the spark plugs, only one of them was oil fouled, the rest were only a little "ashy". Compression test for that cylinder was 185-200. Whereas the rest were between 174-176.
What does this mean?
The valve seal is simple to replace. short version remove the rockers, use an air fitting to put air into the cylinder, compress the valve spring and remove the locks, remove the spring, remove the bad seal, then reverse the process.
The type of vehicle will effect how long it takes F-bodys are a little more difficult due to the engine set back.
If you are going to do one you might as well do them all.
I'm sure you could fine a detailed how to somewhere.
Good luck.
