What is this noise?
Old Dec 8, 2013 | 06:22 PM
garygnu's Avatar
maybe improper lifter preload ?what lifters did you use ? maybe you have a bad PS pump .
Old Dec 9, 2013 | 08:47 AM
mchicia1's Avatar
1) No the preload is perfect, right at .050".
2) The video taken is with the belts off. I put that in the first post.
It's either the oil pump or the camshaft. It's going back to stock to sell, so I will have an answer soon. It just sucks because if it's the cam, I can't sell it, and I don't know how to prove to the vendor that it is the cam.
Old Dec 11, 2013 | 01:52 AM
Anthony Williams's Avatar
Thumbs down
My $$$ is on the cam.
Old Dec 12, 2013 | 09:34 PM
mchicia1's Avatar
Would suck, but to prove it's the cam, I will break down to the front cover, swap the oil pump/re align it properly with feeler gauges, put the cover and pulley back on and start it up with no accessories on the car. That way, I'm only pulling the balancer back off and front cover away from pulling the cam back out for another.
Old Jan 9, 2014 | 01:58 PM
mchicia1's Avatar
I found another video with an identical noise and it turned out to be the camshaft.
I am pulling it out next Saturday
My concern is not the added labor. It's what is being worn down by the camshaft to cause that noise? I'm concerned I'll be tearing everything down again even after I fix the noise to fix something else . I'm praying it's not cam bearing being prematurely worn. I can take lifters going bad, that's just a head swap. But cam bearings = motor comes out and gets torn apart.
Video I found
My car
Old Jan 11, 2014 | 01:11 AM
mchicia1's Avatar
Found another video FYI.
Not an ls1, but a comp cam that's whining. Sounds identical. I am just wondering if it's actually causing harm or not. I hope the vendor warranties it.
Old Jan 11, 2014 | 01:16 AM
mchicia1's Avatar
And another
Old Jan 11, 2014 | 01:42 AM
jsteele90's Avatar
well this isnt reassuring i just put a comp cam in my car and its making a whining sound.
Old Jan 11, 2014 | 11:00 AM
Coonass350's Avatar
Wow, I never would've thought that a cam could make a whining sound. Learn something new everday.
Old Jan 11, 2014 | 06:19 PM
mchicia1's Avatar
Same sound as mine and the videos I linked?
I know! Everyone I talk to thinks I'm nuts for swapping the cam to fix this noise.
Old Jan 11, 2014 | 06:40 PM
jsteele90's Avatar
yes it is.
Old Jan 11, 2014 | 08:05 PM
  #32
mchicia1's Avatar
yes it is.
Who did you buy it from?
Take a video of it and post it up. The more the merrier because I have a feeling it's going to be tough to get a warranty replacement.
Old Jan 13, 2014 | 09:44 PM
  #33
jsteele90's Avatar
it was spec'd by Martin@Tick but it is a Comp grind, of course.
Old Feb 17, 2014 | 02:15 PM
  #34
Kip Fabre's Avatar
Originally Posted by 2xLS1
What cam? Some Futral cams (Cam Motion) were known to cause a whisteling noise.
This is true we did have some problems 6 or 7 years ago. We started polishing the cam lobe after grinding after that now we have no problems.
