critique my LQ4 build
I am new to the forum and fairly new to LS motors done several swaps but never done anything to them other than plumb and wire them up and go.
I started with 2005 LQ4 out of GMC truck tore it down it had 200+ miles on it. I installed GMPP Hot cam kit with the springs the machine shop bored .010 over to clean up the walls and installed sealed power pistons H1128CT .050MM did all the valves and polished the crank and balanced everything. I am not looking fro crazy power i am putting it in a 67 Camaro with T56 just to DD and play around with. Is this a pretty good setup and what can i do to add a lil more power if i want to. I plan to use the truck intake with long tube headers.
