Carbon buildup
Old Dec 8, 2013 | 02:41 PM
Rc4mike's Avatar
Default Carbon buildup
I'm starting an engine swap into a 59 apache. My junkyard takeout ls has carbon buildup in intake and intake ports on heads. I'd rather not pull the heads. What's the best way to clean the ports on the heads?
Old Dec 8, 2013 | 02:43 PM
jsteele90's Avatar
brake cleanr
Old Dec 8, 2013 | 07:32 PM
Rc4mike's Avatar
I'm worried about all that carbon dropping into the cylinders as I clean the ports on the heads. Heads are on the motor. Do u just stuff a rag down port and hope u can get most of the stuff out without dumping into engine?
Old Dec 8, 2013 | 07:34 PM
jsteele90's Avatar
if you want it done 100 percent, pull the heads and clean them seperate from the engine, plus you can clean the carbon off the pistons this way also.
Old Dec 8, 2013 | 09:00 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Yeah, pull the heads. It'll only cost you some gaskets and bolts.
Old Dec 9, 2013 | 05:00 AM
2000PewterT/A's Avatar
Pull the heads, I wouldn't want all that cleaner/dirt going into the cylinders and possibly causing a condition for cylinder scoring to occur among other things.
Old Dec 11, 2013 | 10:00 PM
Rc4mike's Avatar
Thanks for the help. I pulled heads and having them cleaned plus valve job and new springs installed. Should be ready to go in few days
