Trickflow Timing Chain Tensioner
Old Dec 12, 2013 | 08:11 PM
LilJayV10's Avatar
I'm going to have to pick one of these up. Does it come with the actual damper or do you have to purchase that separately?
Disregard, I found they sell a kit with the damper also.
Old Dec 12, 2013 | 08:34 PM
JakeFusion's Avatar
Super Hulk Smash
I have the GMPP LS6 damper from Katech. It's much more expensive. But it bolts right to the block (if newer and tapped). I got a bad bolt in the kit (or I had oil in the bolt hole) and it broke off in the block. I had to remove it and run an ARP thread chaser through. Some hardware store bolts now hold it in place and it seems to be a nice piece... but VERY expensive.
Old Dec 12, 2013 | 09:07 PM
ckpitt55's Avatar
maybe there's a difference between the grey damper and the tan one....I've got the tan one and had no problems.
Assuming you tried flipping it around and installing it the other way?
Old Dec 12, 2013 | 09:28 PM
Bama99z's Avatar
I dont know if there is a difference between the two or not. But I removed mine yet again tonight. I'm going to check a couple more out tomorrow. Jake thinks that I have a little too much slack in my chain.
Old Dec 12, 2013 | 09:42 PM
LilJayV10's Avatar
Does this bolt between the cam retaining plate between the block?
Old Dec 12, 2013 | 10:42 PM
Burken01's Avatar
It goes over the cam plate..
