Trickflow Timing Chain Tensioner
Old Dec 10, 2013 | 09:19 PM
Bama99z's Avatar
Default Trickflow Timing Chain Tensioner
Anybody running the Trickflow timing chain tensioner? If so do you happen to have any pics of it once it was originally installed?
I installed mine lastnight. Sorry no pics yet. I was a little suprised that it didn't tighten up the chain no more than it did. The install was pretty straightforward. I just thiught that It should of been tighter.
Old Dec 10, 2013 | 10:22 PM
Burken01's Avatar
I installed mine, but never took pics.. It looks like it will mainly stop the chain from whipping around vs putting tension on the chain itself.. If it was tensioned very tight against the chain I'd be worried of it wearing down over time..
Old Dec 10, 2013 | 11:18 PM
SIG-054's Avatar
This?
Old Dec 11, 2013 | 01:57 AM
ls1 1990 VN's Avatar
It is a damper, 'NOT' a tensioner. it help stops the chain from whipping.
What chain did you use! Dual chains aren't that tight, LS2 neither compared to the Cloyes C5R
Old Dec 11, 2013 | 05:13 AM
Bama99z's Avatar
Burken01,Thank's I'll snap a couple of pics the nexr time I'm out at the shop and post them up.
Originally Posted by SIG-054
This?
This is what I was expecting mine to look like,
I used a GM LS2 chain.
Old Dec 11, 2013 | 06:52 AM
ckpitt55's Avatar
i'm using the cloyes hexajust timing set. the chain was pretty tight once installed - but i do believe it is intentionally undersized to take out some of the slack.
agree with the others though, its a damper not a tensioner.
Old Dec 11, 2013 | 07:27 AM
JakeFusion's Avatar
Super Hulk Smash
My dual chain was tight as a ****...
Old Dec 11, 2013 | 08:07 PM
Bama99z's Avatar
Guys here are a few pics that I snapped tonight while I was out at the shop.
I noticed that once I tried to install the oil pump tonight that the oil pump is hitting the bolt on the right. The dampener is supplied with ( 2 ) alumiumn spacers. However with the washers installed the bolts hit. They are .250 thick. So I guess that I'll have to take them to work tomorrow and machine them down about half. I removed the spacer to see it that would work, It is designed to use the spacer. When the spacer is installed it actually pushes in on the dampener to assist in mating everything up and allow everything to tighten correctly.
I can't seem to catch a break!!!
Old Dec 11, 2013 | 08:22 PM
speedtigger's Avatar
Old School Heavy
Wow. How long as this thing been out there?
http://www.trickflow.com/partdetail....N=400098++150+
I would have loved to have put one of these on my motor last cam install.
Old Dec 11, 2013 | 08:25 PM
Bama99z's Avatar
For some reason I can't post any pictures tonight. I'll try to get them up later tonight or tomorrow.
Old Dec 11, 2013 | 09:08 PM
ckpitt55's Avatar
Did you remove the OEM "load bearing spacers" that come assembled to the damper prior to install, as per the directions?
If you didn't, that could be causing your problem.
When I installed mine, I did not have to space my pump out and have no interference problems.
Old Dec 11, 2013 | 11:57 PM
I'd been looking at this kit with the LS2 Damper for a couple of years, so when a new cam was installed this year, 'in it went' Happy as now with Cloyes hex a just timing gears & Cloyes C5R chain.
Old Dec 12, 2013 | 05:15 AM
Bama99z's Avatar
Here is a few pictures of my setup.
Attached Thumbnails Trickflow Timing Chain Tensioner-trickflow-dampener-1.jpg   Trickflow Timing Chain Tensioner-trickflow-dampener-2.jpg   Trickflow Timing Chain Tensioner-trickflow-dampener-3.jpg
Old Dec 12, 2013 | 06:39 AM
Paul Bell's Avatar
That's MISTER MODERATOR
I bought one of these and the block adapter for my upcoming LS1 build.
Old Dec 12, 2013 | 07:26 AM
ckpitt55's Avatar
the bolts should not be sticking out that far, something is wrong. mine are flush or even a little below flush with the damper. did you remove the OEM "load bushings"?
http://static.summitracing.com/globa...s-30675600.pdf
Originally Posted by Trickflow
*Note: Remove OEM load bushings from damper prior to assembly to adapter bracket.
Old Dec 12, 2013 | 02:27 PM
Burken01's Avatar
Exactly, gotta pop out the ring underneath the bolt so the bolt head can tighten into the hole.
Old Dec 12, 2013 | 05:45 PM
Bama99z's Avatar
Yeah man I did remove what I think is the OEM load bushing. When the part arrived there were ( 2 ) longer bolts and a spacer in the dampener. I removed them as it you leave the spacers in the dampener will not go onto the bracket. However there are ( 2 ) 1/4" alumiumn spacers included. According to the Installation instructions it shows that these have to be installed. I may not be correct though. I tried to leave them out and the allen bolt appeared th not tighten up all of the way. I'm gonna head out in a little while maybe its about the degrees here tonight so Im waithing for the shop to warm up a little.
Burken, I have done that but it appears that the bolt wont tighten all og the way up to it and bottom out. I was affraid that if the bolt doesn't tighten up all of the way then the dampener could possibly loosen and cause more of a problem.
The big brown truck dropped off a couple more things today!!!
Attached Thumbnails Trickflow Timing Chain Tensioner-arp-head-studs-12.12.2013.jpg   Trickflow Timing Chain Tensioner-ati-dampener-12.12.2013.jpg
Old Dec 12, 2013 | 05:50 PM
Burken01's Avatar
Did you use the wrong button head bolts on the cam plate?
The TFS damper bracket comes with 5 bolts, maybe you used the shorter ones on the cam plate and are trying to use the long ones right now and that's why it isn't working.. Too much slack..
Old Dec 12, 2013 | 05:57 PM
Bama99z's Avatar
Nah, I got the correct bolts in the correct location it's pretty straight forward.
Old Dec 12, 2013 | 06:56 PM
Burken01's Avatar
That's just weird, take a dremel and lop off a few mm's off the end of the bolts and call it a day
