Need help on heads, 241-ls6-243s or??
1. is it worth having my 241s ported, if so who has the best reputation.
2.243-ls6-799 heads, will the out perform the 241 castings if both heads are ported the same, and both heads are using the same valve components?
3. or should I just run a set of AFRs or Trickflow heads, and will they have more porting potential down the road for my later build.
4. Also I have looked and looked, what is the biggest valve size able to run on a stock bottom end ls1? ill say with a mid 65x/65x lift cam?
please guide me toward the right head choice for me, thanks guys!!
The 243/799 heads, however, are a better head to start with, so if a full porting treatment is in the plan, they are the better value.
Now, if you can afford a set of aftermarket castings, like some TFS or AFR heads, then I wouldn't hesitate to recommend them over any of the OEM castings.
You could also fit a really big valve in the stock LS1 bore, but everyone has an opinion about how big you should put in there. Personally, I wouldn't hesitate with a 2.125" or bigger intake valve.
