No warning, how can this be?
Stick cars have a heavy thick flywheel.
I don't know if I mentioned this to you or not Paul, but my husband was born in Queens, NY
The sound only happens when the valve cover is installed? That's weird. If it's stock valvetrain, it's probably not hitting the valve cover, unless a rocker arm broke or valvespring broke and the pushrod is just smashing the destroy piece into the valve cover. But you'd see that.
By the way, HAPPY NEW YEARS EVE everyone!!
I am also testing to see if I did this right or not. lol
As far as the water leaking from the cowl onto the intake; I have read alot about this and really thought it wasnt a intake gasket concern as much as a fuel injector o-ring concern. I recall #7 being the biggest problem with t/a's.....Just my .02
