Oil Cooler Adapter Question
I installed an oil cooler adapter to my LQ4/LS3 hybrid similar to this one:
http://www.improvedracing.com/cooler...ines-p-68.html.
Someone recommended to me that on first start up "you don't want to have to wait for the oil to fill a cooler also - cap the adapter and the plumb the cooler after your break-in". So on went two 8AN caps.
Well I've been trying to fire my new motor but I am running into computer issues, but that is another story. I have cranked my motor probably 20 times trying to trouble shoot coil/ignition issues. I have not seen oil pressure on my Autometer electric gauge, but figured it was because of the low cranking rpm.
I am think that by capping the oil cooler adapter I have block oil flow!!!!
The adapter says "in" and "out" so it really needs to be looped, not capped - right?
I looked up the LS oil flow diagram and the adapter bolts to where the oil bypass would go. So the bypass allows oil to still flow if the filter becomes blocked BUT will the filter still flow if the bypass is blocked (because that is pretty much what I did)?
This is such a bone-headed, amateur move. Can someone please verify or deny my thinking here.
I think new crank and rod bearings are going to be on order.
Whoever told you this was an issue and to cap the adapter lines was incorrect.
The same happens when you change the oil-the filter takes a second or two to fill. Typical cold oil start up pressures is around 60 PSI. The start up circulation is pretty quick.
Get the engine running before you scare yourself into thinking damage is done.
A very experienced engine builder I spoke with said "you have to be honest with yourself and think about how much you cranked this motor with no oil circulating in it. If you had spun it with no plugs in it for priming purposes that's one thing, but when you plug that hole and the cylinder sees compression, now the rod is pressing hard on the crank journal"
I figure it's a lot cheaper for a new set of bearings now (if it needs it) rather than a tear down and rebuild in the worst case scenario down the road.
It just sucks that I was getting so close to finishing this project and now I've taken a step backwards. I'm totally annoyed with myself.
Thanks
So I unscrewed sending unit and tested it with compressed air. It worked - ???
When I reinstalled it gauge was now showing 40 psi when cranking - like it was stuck or something previously.
Got the car started and ran for 20min - temp and oil pressure all good with ecu going into learn mode (Holley HP).
Now for the engine shop to check the filter - I'm hoping all will be good.
