when to change cam bearings
Old Dec 27, 2013 | 05:43 PM
billymgb1000's Avatar
Default when to change cam bearings
I am doing a cam swap and the cam in it has about 120,000 miles but there is no groves in the bearings or cam. I am hoping that I don't have to change em because I have to drag the block to the machine shop to do it,how would you do cam bearings when the motor is in the car? just wondering
Old Dec 27, 2013 | 11:14 PM
cosbysweater's Avatar
Just look at the wear on the bearing, run your fingers down the bearing surface and see off you feel anything abnormal, most cases on all the rebuilds I have done I have not needed to swap out cam bearing
Old Dec 28, 2013 | 12:51 PM
thanks for the help
Old Dec 29, 2013 | 09:41 AM
RezinTexas's Avatar
After you confirm there are no major scratches or gouges, measure the clearance from your new cam to the existing bearings. If is between about 0.002-0.006" you can run it no problem.
See post 11, this is a solid source.
https://ls1tech.com/forums/generatio...d-replace.html
