Patriot heads yes or no?
Old 05-09-2004, 07:54 PM
ONGRNGO's Avatar
Default Patriot heads yes or no?
Hey guys I am looking into a pair of heads and was wondering what you guys thought of the stage 2 5.3 heads from Patriot? I will be going with the TSP 231/237 as far as a cam. Would this be a good combo? Otherwise let me know some other good combos that come to your mind that will make good power thanks a lot.
Dan
Old 05-09-2004, 08:00 PM
SSean's Avatar
There are some guys putting down some pretty serious power with that heads/cam set up. Patriot heads seem to be doing failry well so far
Old 05-09-2004, 08:22 PM
LS1TECH Sponsor
foff667's Avatar
i added about 75hp & 30ft lbs with the cheapy 5.7 perimeter bolt heads and that cam just make sure you get some serious gear if you get that cam
Old 05-09-2004, 08:25 PM
gomer's Avatar
With that cam and a set of Patriot LS6 styles I made 451rwhp and 404rwtq back last year with all belts, no electric wp, and no ported TB... all on a TSP mail order tune.
Old 05-09-2004, 08:27 PM
ONGRNGO's Avatar
Yep I am getting a 9" and was thinking the 4.30 gears, then run a 27" ET Street or would I need 28"?
Old 05-09-2004, 08:28 PM
LS1TECH Sponsor
foff667's Avatar
you want to go with the smallest tire you can for less rolling resistance, weight and such...the 27" probably would be fine...but ask around to see where you'll be crossing the traps with that combo of gears, power & tires before you make your decision.
Old 05-09-2004, 08:57 PM
Classic's Avatar
Both me, and a friend, ran a 9'' with 4.30 gears and 27'' Hoosier QTPs and that was pretty much dead on for our H/C cars. Just off the top of my head I believe you can cross the traps at like 128 maybe with a 6800 rpm, but I may be mistaken - its been awhile.
Old 05-09-2004, 09:07 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Loko into the "hand finished" Stage 2 5.3's being offered by Patriot now. They're supposed to make 10cfm more than the standard off the shelf CNC'd.
Old 05-09-2004, 09:50 PM
slyws6's Avatar
Sounds like a good setup to me, should put down some good numbers.
-Sly
Old 05-09-2004, 10:17 PM
Ryan02SS's Avatar
Sounds like a good combo. I'm going with the 5.3s also for my TR224 cam. I'm hoping for 425+ rwhp after Mikey tunes my car again. Search the dyno forum as their are a few cars with your same setup making good power.
Old 05-09-2004, 10:18 PM
Mike98WS6's Avatar
I'm very happy with my PP 5.3 stage 2's and 231/237 cam combo.
Old 05-10-2004, 02:51 AM
pdd
pdd's Avatar
yes. a proven combo
Old 05-10-2004, 07:40 AM
JoeyGC5's Avatar
Originally Posted by pdd
yes. a proven combo
What pdd said
Old 05-10-2004, 07:49 AM
killer01ws6's Avatar
Cool
This is the route I am going.
Old 05-10-2004, 11:38 AM
ONGRNGO's Avatar
Do you have any new Dyno numbers or 1/4 mile passes with your new setup?
Old 05-10-2004, 02:21 PM
98sspullin'em's Avatar
i have the pp 5.3's and the tr 230 and i like it... havent got it dyno'd yet but i have went to the track just once and ran 11.4 with some spin..
Old 05-10-2004, 02:43 PM
nick y's Avatar
Dan
HEY DAN-YES
my car screams!!
417 w/out ported tb on stock mufflers and runcraps. a4 btw if i can pull a 1.5 w/good air ill go 10.99
Old 05-10-2004, 04:24 PM
BRIAN98Z28's Avatar
how much of a difference HP wise is 10cfm going to make with the added cost of the $400 hand finishing? is it really worth it???
Old 05-10-2004, 04:26 PM
LS1TECH Sponsor
foff667's Avatar
it depends really on if thats just peak or how much it helps lower in the lift ie .200-.500 as well otherwise eh...for me if the $400 doesnt include the larger valves I dont think its worth it.
Old 05-10-2004, 04:47 PM
!LS1 11 Second Club
https://ls1tech.com/forums/dynamometer-results-comparisons/164247-tsp-225-camshaft-tsp-5-3l-r-results.html
