1998 z/28 needs motor replaced
Old Dec 29, 2013 | 11:10 PM
ss426's Avatar
Default 1998 z/28 needs motor replaced
My motor let go vented block found a 2001 motor will it work new to the Ls scene will any short block work and will heads interchange I know valve covers are different thanks
Old Dec 30, 2013 | 02:06 AM
Burken01's Avatar
Yes swap the 98 heads/ valve covers over to it.
Everything else will bolt up normally
Old Dec 30, 2013 | 03:11 AM
98WhiteLsX's Avatar
Knock sensor, cam or crank is different too. And the 2001 came with a 2 wire sensor in the head for temperature. Change those 3 sensors and you're good. I'd change over every sensor though
Old Dec 30, 2013 | 10:37 AM
mjs1012's Avatar
This is what I did when I swapped in a 2000 motor into my 98. Put the 98 sensors and fuel injectors on the new one and itll be good to go.
