What should I get done to my 241 heads?
Currently I have 853 casting heads on my 2000 Z28 m6 with the LS6 intake, 373 gears, and a 224/228 .581 .588 112lsa cam and made 392rwhp and 375lbs tq on the Dyno with what's listed above with the exception of the 373s. I picked up a pair of 241s from a 2002 Camaro SS and am trying to figure out what to do to get the most out of them that'll go well with my setup. The idea I've got for them so far is Port/Port match, Polish exhaust side, .2 mill, 3 angle valve job, and bowl blending. And then to go with that, cometic .040 head gaskets, 7.375 pushrods, ls7 lifters, and arp studs.
Does this sound like a good plan for the heads for my setup or does it need to be changed up a little bit?
Thanks guys,
-Alex
Thanks guys,
-Alex
Sell the 241s and buy some 243s and have them CNC ported and gain 35-50 HP. The 241s work good also with a CNC port job but the 243s will out flow them. Just depends on your budget and what you want to spend. The 241s flow about the same as your 853s anyway.
AI claims "40-55rwhp SAE range over the as cast 241" with their High CR CNC package, alone.
They claim 40-50 over "as cast" 243's, but the as cast 243's have a gain over as cast 241's, so your best best is 243's, but don't think the 241's can't make power.
http://advancedinduction.com/LSX/AiLSxCylinderHeads.php
Good read: https://ls1tech.com/forums/dynamomet...o-results.html
your best bet,dollar wise,is to send your 241s to one of the sponsors mentioned.properly ported with the right valve job,those 241s will make plenty of power.
if money is tight,AI has a lower cost option that involves,cleaning,inspecting,valve job and milling to your spec.
the right valve job alone is worth a few horses..
Thanks for all the responses guys. I forgot to mention I will also be throwing some 42lbs injectors. With AI's 241 choices should I get 219 CC heads or their high CR 219 CC heads? Which would go better with my setup? And what should I do about head gasket size or pushrod size if I go with their heads?
If your planning on keeping your car forever(it's your dream car) sell both your 853 and 241 castings and go get a set of the best heads on the market and be done... Trick flows, afr, mast, I'm going to get Texas speed as cast 225s...for the money you put into rebuilding the 241s you could just get some sick *** heads
Like Mac said, AI will answer all of your questions for you. Remember, to achieve the higher compression, they have to shave the heads down, so that brings your valves closer to the top of the piston.
You will more than likely be using a stock thickness gasket.
Whats the stock size? Other dude running these heads with a bigger cam than the OP used Felpro 0.040 gaskets and ran 11.5:1
Stock is .052 to .055 crushed for the graphite gasket, and iirc, the MLS is .060.
I'm not saying he can't necessarily use a thinner one, just saying that he needs to be aware of the decreased PTV clearance after they mill the heads, and buy parts accordingly.
The HC241s he is quoting maintain stock PTV.
