ppl running prc 225 heads come in
Old Jan 5, 2014 | 06:19 PM
bigantws6's Avatar
Default ppl running prc 225 heads come in
bout to get ready to order me a set of prc 225 as cast heads and wanted to get ppl input that are running these heads. ill be running these on sbe ls1
Old Jan 6, 2014 | 08:34 AM
unstable Vic's Avatar
I'm interested as well. Make sure you get the right valve guides to use your stock rockers. The bronze ones won't work I'm told.
Old Jan 6, 2014 | 11:40 AM
bigantws6's Avatar
Alright thanks for the heads up illask before i put my order in
Old Jan 6, 2014 | 04:25 PM
Darkstar632's Avatar
I'll be buying these heads next week, can't wait to see what numbers my car puts down
Old Jan 7, 2014 | 01:56 PM
standerson's Avatar
I think they are great heads for the money. I put these heads on with Tick's SNS stage 2 cam in my 02 ls1 and I put down 445rwhp and 410rwtq on a dynojet in 90 degree weather.
Old Jan 8, 2014 | 09:03 PM
bigantws6's Avatar
Dark star let me know how they work out of u @standerson was that threw a auto and what's the spec on that cam
Old Jan 9, 2014 | 09:20 AM
standerson's Avatar
It was through a manual trans. I believe the cam specs on SNS stage 2 are 227/235 .614 /.621
Old Jan 9, 2014 | 11:07 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Those heads are a great bang for the buck as far as aftermarket castings go! Unstable Vic, you're a little misinformed. For most companies you would be correct but with the quality of bronze that we use in those heads you can still run stock rocker arms with the bronze valve guides.
Lonnie
Old Jan 11, 2014 | 11:34 PM
Lonnie
Lonnie, will the as casts be fine with my ms3 cam(238/242 605/610 lift 110LSA), and I'm going to measure and reorder pushrods, but curious as to what length most people are ordering with them
Old Jan 13, 2014 | 08:51 PM
00ssmg's Avatar
Big am supprised there are not more results with these heads. I have a set sitting waiting on other part to help them out. Are people just not willing to post them or are there really no body running them
Old Jan 14, 2014 | 06:14 AM
Really? Interesting. I thought bronze was bronze. Powder metal I thought was what is needed to run stock rockers and not a roller rocker. That was the issue with the trick flow heads right?
Old Jan 14, 2014 | 06:28 AM
BOBS99SS's Avatar
Captain Double Post
if you search you will find out alot more info, great heads imo, i remember a few past threads , ill see if i can dig them up later on
