heads and cam
AI has heads/cam combos on their site.
TEA can recommend cam specs or do what i did...I went with a set of TEA heads and called Martin Smallwood at Tick performance and had him spec a custom cam for me. he worked hand in hand with TEA to make sure my heads were set up properly for the cam.
The customer service was absolutely top notch.
Heads - ~1200
Cam - 400
be sure to add in a trunion upgrade for your stock rockers, new gaskets, all the misc stuff, pushrods, etc...
You should come in right around ~2500 to do it right the first time and be in the ballpark of ~450whp...conservatively...especially since you'll be starting with 243's and higher compression compared to me and my 241 head package...
Also, you'll want to check your pushrod length to make sure everything is perfect.
