Improved Racing Crank Scrapers
There were some delays at the machine shop because some crackheads literally stole the power lines outside the building
. They had to get a permit and hire a contractor etc to get everything reinstalled and running again. The Best V8 Stories One Small Block at Time
http://www.improvedracing.com/oiling...rs-c-3_50.html
To summarize fitment once again:
EGM-300 - F-Body oil pan with completely stock bottom end with factory main studs only. We will be phasing out the F-Body specific crank scrapers so in the future you will just use the other models below with the F-Body oil pan.
EGM-301 - 3.622" stroke LS engines with completely stock bottom ends with factory main studs only. Aftermarket rod bolts and aftermarket rods will fit with some minor notching. Current stock does not fit forged crankshafts such as LSA and LS9 without modification, but the next batch will work with those engines as well as fit ARP rod bolts.
EGM-303 - All 3.622" crankshafts, including forged crankshafts such as LSA and LS9. Fits ARP main studs only (will not fit factory main studs). Works with ARP rod bolts and most aftermarket rods.
EGM-305 - Designed to fit Manley 4.000" crankshafts and forged rods. Will fit most other 4.000" crankshafts with no modification, but some may require minor notching. ARP main studs only (will not fit factory main studs). Works with ARP rod bolts and most aftermarket rods.
