Copper in oil..
I was changing the oil in my '05 CTS-V this evening and noticed a copper colored streak as the oil was draining. It was draining into a closed style drain pan, so I couldn't get a good look at the old oil. There wasn't anything on the magnetic plug. The filter had a small amount of copper dust in the oil, but I haven't cut it open yet.
I refilled the oil, started the car and listened to the top end with a stethoscope. It develops a slight tick from the valve train once it's warmed. I had the rocker covers and valley covers off about 2,000 miles ago and didn't see any discrepancies. The car has 103,000 miles. I've had it since 50,000 and have been pretty gentle with it.
So I've got a bearing going out somewhere. So my question is, other than the mains that "make" copper when going bad, what other bearings should I check?
Oil filter cutters are glorified pipe cutters. They open the filter without introducing metal shavings from the filter case via sawing or grinding. In aviation, every time you change the oil on a recip. the filter is opened and inspected.
