Single or double timing chain?
Old Jan 14, 2014 | 11:02 AM
ls1 1990 VN's Avatar
Originally Posted by mchicia1
Jake, did you drill and tap for the damper or did your block have the provision?
I 'think' Jake did as I did & fitted the Trick Flow Damper kit, i used the LS2 Damper
Old Jan 14, 2014 | 11:48 AM
JakeFusion's Avatar
Super Hulk Smash
I am using the genuine LS6 damper. Block was drilled and tapped for it. Got it from Katech.
Old Jan 14, 2014 | 01:11 PM
mchicia1's Avatar
Cool thanks.
I just ordered the c5r katech chain just now since I'm gonna be swapping cams again. I figured with my luck, I better get that ls2 chain outta there. $150 chain vs $3500 forged 347, hmmm .
I'm not gonna drill for the damper though, too risky with the engine in the car imo.
Old Jan 14, 2014 | 01:56 PM
chevybayboy's Avatar
I also got the Ls6 dampner from katech
