Single or double timing chain?
Old Jan 12, 2014 | 05:25 PM
BEAns_99's Avatar
Default Single or double timing chain?
What do you recomend? Single or double? Ls2 timing chain?
Thanks!
Old Jan 12, 2014 | 05:32 PM
conan's Avatar
Whats the application ? Drag car, street car, road course racing, HP goal ???
Old Jan 12, 2014 | 08:25 PM
BEAns_99's Avatar
Well im doing a tick sns3 cam and im shooting for the 400+ hp street and strip not my DD
Old Jan 12, 2014 | 10:03 PM
conan's Avatar
LS2 chain will be plenty for your setup.
Old Jan 13, 2014 | 05:35 AM
BEAns_99's Avatar
Single you mean?
Old Jan 13, 2014 | 09:08 AM
DANOZ28's Avatar
the ls2 chain is a single chain thats aprox 50% stronger than the ls1. i thinks its plenty but call some speed shops for a 2nd opinion. ive been running an ls2 chain for 5 years with no problems.
Old Jan 13, 2014 | 09:28 AM
Baconz28's Avatar
Um building a 450 plus horsepower tire engine. At 40 bucks the ls2 chain is a great source. I just have nightmares about revving my engine high with a single chain so I'm just go dish out a 120 bucks for a double chaon. Either A Roll Master Or The Trickflow Double chain.
Old Jan 13, 2014 | 10:11 AM
conan's Avatar
Originally Posted by BEAns_99
Single you mean?
What he said. ^^^
Old Jan 13, 2014 | 01:03 PM
z28SSilvest's Avatar
LS2 chain.
Old Jan 13, 2014 | 04:33 PM
chevybayboy's Avatar
I talked to Texas speed and one of the guys told me they use the single in their racecar
Old Jan 13, 2014 | 04:42 PM
Gray86hatch's Avatar
If you are killing chains you need to look at your balancer.
Tim
Old Jan 13, 2014 | 06:22 PM
BEAns_99's Avatar
Thanks for all you input guys! Ill be geting the single Ls2 chain and see how it goes!
Old Jan 14, 2014 | 03:18 AM
ls1 1990 VN's Avatar
Cloyes Hex a just gear set with the extreme duty C5R chain & you won't worry again
Old Jan 14, 2014 | 03:22 AM
Burken01's Avatar
Tim
Ding ding ding...
Old Jan 14, 2014 | 03:42 AM
itsslow98's Avatar
Ls2 is what I put in both of mine.
Old Jan 14, 2014 | 06:26 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Rollmaster single here.
Old Jan 14, 2014 | 06:42 AM
Exidous's Avatar
Katech uses a single in their C6.R LeMans race car. Just sayn. :-)
Old Jan 14, 2014 | 09:06 AM
KCS's Avatar
KCS
Moderator
I like using single roller chains so I don't have to clearance anything, and I have an NMotion billet single roller set in my car. With that said, I have seen a broken single chain though.
Old Jan 14, 2014 | 09:15 AM
JakeFusion's Avatar
Super Hulk Smash
I put a Rollmaster Double roller in... it's more work.
If I had to do it over, I'd do the Cloyes Hex-A-Just with the C5R chain... I'd definitely do a chain with billet adjustable gears.
I'd also invest in a quality balancer and timing chain damper. I have the ATI on mine with the Katech LS6 damper. Both of those will save your chain from breaking due to harmonics...
Old Jan 14, 2014 | 10:17 AM
mchicia1's Avatar
Jake, did you drill and tap for the damper or did your block have the provision?
