98 Camaro ss feeling slow
Old Jan 12, 2014 | 09:34 PM
Tdadddyz28ss's Avatar
Default 98 Camaro ss feeling slow
My 98 Camaro Ss m6 is feeling slow it's not bogging down it just feels to not to have as much pick up until about 3500 a stock evo x ran away from me in a 30 roll and my tranny chatters under hard shifts (feels like wheel hop ) but I don't think it is cause it doesn't all the way through 5th open to any suggestions performance mods slp lm1 k&n fipk 373s ls7 clutch b&n ripper 79k
Old Jan 12, 2014 | 11:45 PM
ls1 1990 VN's Avatar
Punctuation would help!
Old Jan 12, 2014 | 11:59 PM
Bad28's Avatar
Being that low of milage I'm assuming it sets a lot you may try sea foaming it they have it stickied on how to do it
Also may try plugs wires air filter
Old Jan 13, 2014 | 01:27 AM
chevybayboy's Avatar
Really, is it that serious??
Old Jan 13, 2014 | 07:48 AM
Haha yes I'm sorry it was late and I was tired.
Old Jan 13, 2014 | 07:51 AM
I picked up a set of ngks plugs I'm going to do soon I assume that they original plugs are still in there. Could it be an issue of clogged injectors or a bad coil pack?
Old Jan 13, 2014 | 11:09 AM
When trying to read someones story without punctuation it can be interpreted competely different.
If someone is asking for help, why should someone else have to mentally punctuate their continuous speel to sort out what they are asking.
OP thanks for your explanation.
Old Jan 13, 2014 | 11:42 AM
ds98formula's Avatar
Also clean the maf.
Old Jan 13, 2014 | 11:47 AM
Originally Posted by ds98formula
Also clean the maf.
I took it out and cleaned it about 4 weeks ago it didn't seem to dirty but I sprayed it down with crc
Old Jan 13, 2014 | 11:57 AM
Well look into the trans noise. How many miles in the clutch? How is the engament? Sounds like you are haveing problems with engagement at high rpms.
Old Jan 13, 2014 | 12:00 PM
mchicia1's Avatar
You need to get a benchmark on it. Either dyno it or take it to the track and get a MPH for it.
Cars always feel slow after a while.
Old Jan 13, 2014 | 12:36 PM
Um probably around 700-1000 miles just put it in about a month ago. I mean under normal driving and medium load it's fine and smooth
Old Jan 13, 2014 | 01:08 PM
Any chattering would concern me.
Old Jan 13, 2014 | 01:24 PM
z28SSilvest's Avatar
Get a dyno tune, even if its stock
Old Jan 13, 2014 | 01:42 PM
What could it possibly be? I've never experienced anything like it
Old Jan 13, 2014 | 02:33 PM
https://ls1tech.com/forums/manual-tr...tml?styleid=26
There are a few threads about it. Here is one but it can be a lot of diffrent things. Break in, faulty hydrolics, contamination on clutch/flywheel
Old Jan 13, 2014 | 03:19 PM
Thanks I appreciate bro
Old Jan 13, 2014 | 03:21 PM
Gotcha. Just thought you were trying to be a di*k about it
