Remote Idle Control Valve??
Old Jan 13, 2014 | 02:06 AM
VRSenator065's Avatar
Default Remote Idle Control Valve??
Hi all, I am running an 8 ITB set up. I want run a Idle Control Valve. Does anybody know of anyone who makes a block that accepts the standard LS1 valve, that I can fit on the firewall then plumb into a manifold vacuum block?
All help really appreciated
edit: this is the kind of thing I am looking for that will talk to an LS1 ECU
Old Jan 13, 2014 | 06:29 PM
For anyone else needing this, thought I would post a couple of links to two options.
http://www.efihardware.com/products/...otor-block-ls1
http://www.ebay.com.au/itm/120984745962
Old Jan 13, 2014 | 06:49 PM
LPE 403's Avatar
I did a remote IAC for mine....
http://www.fuelairspark.com/fas/remo...-w-filterhtml/
Old Jan 14, 2014 | 04:17 AM
Very nice, did find that one, did it hook up directly to the original ECU?
Old Jan 14, 2014 | 05:19 AM
LPE 403's Avatar
Yep.... Plug and play.
Old Jan 14, 2014 | 04:13 PM
Thanks for that, have already bought the Aussie version off EFI Hardware, but good to know there is an alternative. cheers
