Help Needed/Couple Questions Regarding A New Setup
Old Jan 16, 2014 | 11:10 AM
1BAD98LS1's Avatar
Riseof the phoenix...I seriously doubt the 44lb/hr injectors is enough to get you to the desired rpm range. I'm doing 60lb siemens on my 346 and probably wont go past 7500. This way there is some wiggle room for later on too. I assume you drive your car on the street during rainstorms as to why you want your wipers?? I got rid of my wipers and the cowl got hacked off and it can be driven on the street still. Will gladly send you a pic of it and you will see it doesn't look bad at all. And will look real nice with the 5" VFN...I'd lean toward supervic but that's just me.
Old Jan 16, 2014 | 12:27 PM
Rise of the Phoenix's Avatar
Yeah, I'd love to see some pics. If you can post them up on here, that would be great, or you could e-mail them to me:
nathansuttenfield@ccrsi.org
I drive the car on the street, but never in the rain. The only reason I would want to keep them is for inspection purposes, as I don't see how it would pass without them. I already take the car to a "friendly" place, but I don't think they would pass the car without wipers. If that was not an issue, I'd remove the cowl and get a 5" VFN hood, which is what I want anyway.
Old Jan 16, 2014 | 02:23 PM
Originally Posted by bozzhawg
E85 is different from pump gas, the biggest difference is the SFR (stoci). E85 is 10.0.
You are talking about putting down 600-675ish BHP and you want the injectors to work 80% or below thats why I said 85-90's lb/hr. You should not run out of injector.
Just depends on how extreme you want to go with the car. You can do the dual pumps (aero or deutch) Aeromotive fuel regulator, a good teflon fuel line -8 would work.
Personally I would probably say the hell with it and go for more displacement. The amount of money your gonna spend to prep the car to get to this point, you could have spent that on a larger displacement shortblock. You got the heads already.
Add you a 50-100 shot on the bigger cubes and call it a day.
Will an 85-90 injector be ok on say, a 150 to 200 shot, or would I need bigger? Remember, I'll be adding a Nitrous Outlet Stinger Plate system too.
I see what you're saying about upping the cubes, but honestly, my stock shortblock only has 45k on it and I've already got upgraded ARP rod bolts, so I'm just going to roll with it. I will sell my LS6 intake, rails, injectors, TB and SLP lid and filter, so I'll be able to put that money toward the Super Vic./4150 TB and all the small things I'll need to make the transition. Obviously, I'll need the fuel components too, but I'd need those even if I went bigger cubes, so that's a wash.
Old Jan 16, 2014 | 08:09 PM
1BAD98LS1's Avatar
The inspection sticker is definitely an issue when thinking about removing wipers...start making buddies with inspectors, maybe take um to lunch or something lol PM me your number, for some reason it never works when I send pics to email addresses.
Old Jan 16, 2014 | 08:16 PM
1BAD98LS1's Avatar
I think there's a chart somewhere on here where you calculate HP/injector percentages etc.. Being that e85 burns so fast and your adding nitrous you may want to look into the 80+ lb'ers. I missed the part about you adding n20 that's why I said 60lb earlier which would be fine for just e85 alone.
Old Jan 16, 2014 | 09:43 PM
So 80's would work, but would it hurt to step up to a size bigger? I would think having more injector than you need would be better than just having enough or is it counterproductive to have too much injector?
Old Jan 17, 2014 | 03:05 AM
My6speedZ's Avatar
If you have good injector data you can get larger injectors to idle well enough.
I like this injector calculator because it shows E85 and Pump: http://fuelinjectorclinic.com/flow-calculator
The BSFC is going to be different if your planning on spraying it alot so take into consideration if it is going to be a dry shot from that plate to set the BSFC to nitrous so it will incorporate the extra demand for fuel into the injector size. If the fuel is going to be coming from a stand alone directly to the plate then just size it accordingly for the E85 in n/a form.
Old Jan 17, 2014 | 08:28 AM
Thanks for that link. According to that, if I were making 550 rwph with fuel pressure at 43.5 and a duty cycle at 80%, I would need 64lb/hr for e85. I don't see an option for Nitrous; just Turbo or Supercharged. I guess 80's will work fine for what I'm planning. The max I'm going to spray will be a 200, wet shot.
Old Jan 17, 2014 | 11:39 AM
Here is a reply I got from Monte Smith regarding my injectors and future setup:
The injectors you have now, will handle over 700hp at a .5 BSFC at 100% duty cycle. So you HAVE enough injector for the motor and if you plan to spray the nitrous wet, that will obviously NOT be injector supplied fuel. So what you have now is fine
Monte
Monte Smith
Motorsports Technical Representative
Nitrous Oxide Systems
Old Jan 17, 2014 | 02:59 PM
That maybe true for pump gas (.5 BSFC) but E85 is (.7 BSFC) 10. stoic vs. 14.7 pump gas you see?
But you are about to run a 13.1 to 14.1 high compression motor with a 200 shot and the last thing you wanna do is be anywhere near 100% duty.
All it takes is one lean spike or N20 spike to occur and you'll be saying bye bye to your motor especially with hyper pistons.
Here is what I use:
BSFC
NA
pump gas=.5
E85= .7
FI/Spray
pump gas .65
E85= .91
Using Monte's assumption of 700BHP:
E85 is .7 that would call for a 77+lb/hr injector NA at 80% and 61+ lb/hr at 100%.
Whatever size you use, just make sure you have that 80% duty cycle cushion. Thats what I would do,but its your car in the end.
Thanks for the great information. I agree that I would never want to run my injectors at 100% duty cycle. I posed that question to Monty on the other Forum; is it safe to run injectors at 100% duty cycle. Based on that calculator you posted, 80's will work find and keep me in the 80% duty cycle, but I may go up a size just in case.
Old Jan 17, 2014 | 03:19 PM
JakeFusion's Avatar
Super Hulk Smash
Bosch EV14 80lbs injectors (@ 42.5psi)... It'd easily cover what you want. And you can get in the EV1 or EV6 size/connector, depending on what you need for the manifold/rail.
Old Jan 17, 2014 | 03:56 PM
  #32
Thanks Jake. I've heard good things about the Bosch injectors.
Old Jan 17, 2014 | 04:03 PM
  #33
My6speedZ's Avatar
Not only that but those injectors are rated at 80lbs at a lower pressure so there is a nice cushion for you.
Old Jan 17, 2014 | 05:45 PM
  #34
JakeFusion's Avatar
Super Hulk Smash
I have the 52s for my NA regular pump gas build. They are 60 at the rail. And the Bosch EV14 is the best design for these engines IMO.
Old Jan 29, 2014 | 08:35 PM
  #35
Surtr66x's Avatar
Hey I need help with these I just bought these for my ws6 running a 102 fast intake and will be orderingthe stage 3 fuel line kit from nasty performance but idk if these injectors are
Short
medium
Tall
Old Jan 30, 2014 | 10:44 AM
  #36
Nasty N8's Avatar
Post or send me a pic of the injectors you have and and we will get you taken care of.
Old Jan 30, 2014 | 10:59 AM
  #37
JakeFusion's Avatar
Super Hulk Smash
Nate will get you hooked up. I went with the LS2 (Medium length) because I used an OEM LS2 rail on my FAST 102. Worked flawlessly. I just had FIC send the EV6 to EV1 connectors so they'd be PnP in the stock wiring harness.
Old Jan 30, 2014 | 11:31 AM
  #38
So connectors can be ordered to make pretty much any injector compatable with the LS2 rails? If I go the FAST 102/102 route, sounds like the best option is to switch over to the LS2 rails. Just want to make sure my current injectors (Accel 44lb/hr) will work. Part number would be great too if you have it.
Old Feb 4, 2014 | 11:24 AM
  #39
Ok, since i found a guy who will inspect and pass my car, I'm for sure going the Super Victor/4150 TB route. I found a cam that I think will work very well. It is 236/248 .631/.631 111 LSA. Now the question is, will it clear my heads. My cam right now is 227/235 110 LSA and I have .069" intake clearance and .101 exhaust clearance. Here is something interesting that a guy posted in a thread I made over on another forum when I asked if that cam would clear: What do you guys think?
Fairly straight forward ....
Find your current cams tdc # on the ICL, multiply by the rocker ratio.
Now take the proposed new cams tdc # on the ICL, multiply by rocker ratio.
Subtract the difference between too. ......walla, new ptv number.....since you already know your current ptv.
This is just an example. .....
current 227 lobe on a 108 ICL @ tdc = 0.070" x 1.7 = 0.119".....this means your intake valve is open 0.119" at the nearest point in the revolution. ..aka; tdc.
New cam lobe 236, on a 106 ICL @ tdc = 0.089" x 1.7 = 0.151"
So.......0.119" minus 0.151" = 0.32"
So, you have 0.069" minus 0.032" = 0.037" of ptv with new 236 lobe on a 108 ICL.
Remember this ^^^^ is just an example.
You just need to find out what lobe family your current cam is and what your new one will be. Also, the same math will figure the exhaust lobe ptv too.
Old Feb 4, 2014 | 04:48 PM
  #40
JakeFusion's Avatar
Super Hulk Smash
What cam is that?
