Help Needed/Couple Questions Regarding A New Setup
I have a few questions before I start on the new intake setup I'm going to be doing here soon. New intake setup will be a Super Victor/Scorpion 4150 TB. I will be getting a new (much bigger) cam spec'd for the new intake/TB setup. I want to run e85 and raise compression between 13:1 and 14:1, which I assume will be safe with running e85 (I know Diet Coke is running 14:1 compression on e85). I will have the heads milled to acheive the desired compression and flycut the pistons for clearance. The first question is will my Accel 44lb/hr handle e85? The first stage of this will be NA, with a Nitrous plate system coming in stage 2. I will need to upgrade my fuel pump (stock one right now), so I was thinking about going dual 340's. I would love some help in picking out what dual pumps to run that will support e85 (keep in mind I'm trying to do this as budget friendly as possible). Will I need to make any other upgrades other than the pumps? Any help would be greatly appreciated.
I was just being conservative on the numbers, but yeah, 540 to 550 would be great. I know I'll have to cut the cowl, but I'd like to do it in a way to keep the wipers, or at least the driver's side one. With the Scorpion TB, I think I can modify my stock WS6 hood to work.
Jake, is 14:1 compression too high for e85?
If you're seriously going to try to make a hundred more rear wheel horse than you have now with no more cubic inches then you'll have to consider twisting it closer to 8 grand than 7. At that point a 223cc runner will be choking the **** out of it. Since anything below 4500 won't matter anymore perhaps a square port LS3 style head in the 255cc range will feed it better and as Jake suggested....solid roller beast !!!!
I would think an E85 set-up would need at least 40% more injector than you have right now. IIRC they run 8-9 afr instead of 12-13ish.
So it sounds like the Victor Jr. may be a better bet for me given the size of my heads. It would fit better for one and I doubt I'd be giving up a lot of power over the Super Vic. I also heard that on smaller cube engines that the Super Vic. actually went slower than a Victor Jr. regarding ET's on the same setup. Any validity to that? Can an intake be too big for a smaller cube engine?
Super Hulk Smash
I don't know. I'd still look at a Super Victor and an EPS 236/248 108+4 Single Plane cam...
Here isa video of a guy who did 440/400 with PRC 215s, Super Vic, Elbow, and EPS Cam... through a big stalled A4 and on a Mustang dyno. I don't think he spun it past 7000. Hard to tell in the video:
Oh and here is the link on here: https://ls1tech.com/forums/generatio...tup-346-a.html
I would think your heads are a little better than the PRC 215s due to the larger port volume for that cam/intake. Btw, that 440/400 was with cutouts closed. Maybe closer to 455-460 open per his assertion it did 18 more with them open before.
Jake, I did see that video and have half *** followed his build. I'll have to take a deeper look at it though. I do not plan to run an elbow; I have heard back to back dyno runs with and without an elbow being upwards of 30 rwhp higher without the elbow.
Super Hulk Smash
I would not run the elbow either. But, that's about the only way you can keep your wipers... or you run a very small filter on top and rip it off when you race.
To be honest, I'd run MAST LS3 small bore heads, a custom cam with very stable lobes, short-travel lifters, and the Super Victor. Run it to 7500-7800.
I would love to run the MAST small bore heads, but I doubt I'll be able to pull that off financially. I guess if I sold my current heads I may be able to swing it, but I think I'll roll with the heads I have.
The plan is to run a very small filter on top, just like the one guy on here does. IllusionalTA if I remember right.
