torquer 2 114 lsa question
Old Jan 30, 2014 | 01:50 PM
redbird555's Avatar
Originally Posted by GMC5.3
Op I'm in the same boat, purchased a new f13 on a 114 lsa for cheap, and I'm wondering about the idle. I was set on keeping it, then i read this damn thread, now you have me wondering again.
Here's my f13 on a 114 untuned but tuned it sounds pretty much the same. The tv2 here on a 114 has 2 degrees more overlap so it will sound a little nastier
http://youtu.be/BlcSsi1Pg0M
Old Jan 30, 2014 | 02:39 PM
GMC5.3's Avatar
Nasty is what I want, damn well I guess I'll hope a cutout adds some lope, that and the tuner
Old Jan 30, 2014 | 02:59 PM
JakeFusion's Avatar
Super Hulk Smash
Please don't buy a cam for sound. Just lower your idle RPM to get lope.
Buy it for what you want - power.
I don't know what TSP grounds into them for advance. I believe it's +2?
114+2 (overlap 5 degrees)
Static Compression Ratio 10.16786291 :1
Dynamic Compresion Ratio 7.594412567 :1
112+2 (overlap 9 degrees)
Dynamic Compresion Ratio 7.7312464 :1
The 112+2 with 9 degrees of overlap will definitely lope more and make more power... and as you can see, has more dynamic compression. But if you throw more compression at the 114+2, it'll drive smoother, peak a little higher, and be slightly more tame.
Old Jan 31, 2014 | 09:59 PM
Stang-Slayer's Avatar
I like the way you talk. What heads would you suggest for mine? (The one from page 1 that has two videos, TV2 114 lsa)
Ported 5.3's?
Old Jan 31, 2014 | 10:24 PM
JakeFusion's Avatar
Super Hulk Smash
Ported 5.3s would be good. TSP 5.3s are a good value. The AI 5.3s rock as well but cost more with new cores/stainless valves.
Old Feb 1, 2014 | 01:56 PM
Ahhhh nice! I went to AI's website, they don't have any prices posted. Any idea?
