Lq9 Compression Check
Old 01-22-2014, 01:25 PM
LSFOX's Avatar
Default Lq9 Compression Check
I am terrible with the calculators and wonder if someone knows a simple way to see if this will work.
stock LQ9 bottom end and untouched 317's is supposed to be 10 to 1 compression with the .051 gasket
Change to the lingenfelter .075 LSA/LS9 gasket
How much will my compression drop?
I have seen somewhere around 2.2CC's gained per .010 of HG thickness but I'm not sure if that's right
going by that I should be ~ 9.47
am I totally off or decently closer here?
I wanna cheaply turbo my LQ9 this year and do a rods and piston setup next winter...
Old 01-22-2014, 02:04 PM
Old Geezer's Avatar
Nothing wrong w/ 10:1, with a good tune.
Old 01-22-2014, 02:10 PM
LSFOX's Avatar
on pump gas at like 15-16lbs?
forgot to put that in there....
Quick Reply: Lq9 Compression Check
