Cam specs odd! Need some input.
Old Jan 23, 2014 | 12:53 AM
JWStevens's Avatar
Default Cam specs odd! Need some input.
I've been looking at this cam for a while now sitting in my shop so it tore my motor down to put it in and now I'm second guessing it because it seems like an odd cam. Its 232/236 542/545 112. Has anybody ran anything even similar to this in an LS1?
Old Jan 23, 2014 | 01:09 AM
99Bluz28's Avatar
Is there any info on the end of the cam...?
Old Jan 23, 2014 | 01:47 AM
itsslow98's Avatar
What do you find odd about it?
Old Jan 23, 2014 | 02:21 AM
soundengineer's Avatar
the lift seems a little low for that duration.... but maybe its a custom grind cam for somebody with 1.8 rockers?
otherwise... the rest of the specs seem pretty normal
Old Jan 23, 2014 | 04:14 AM
DREAMZ28's Avatar
What lobes are those?
Old Jan 23, 2014 | 07:41 AM
JWStevens's Avatar
Its a comp lobe. It was actually bought for stock LS1. I thought about the 1.8 rocker deal too but that wasn't it because I got the whole motor from a friend and it was stock except for the cam. It just seems like the duration doesn't match the low lift.
Old Jan 23, 2014 | 02:30 PM
99Bluz28's Avatar
Looks very similar to Comp Cam Xtreme RPM lobes #3756(232 @.05", lift .541"), and #3757(236@.05", lift .544").
Old Jan 23, 2014 | 03:51 PM
Rise of the Phoenix's Avatar
Similar to the famous Tigershark cam by the one and only Ed Curtis. Not sure what the intake/exhaust lift number are, but pretty sure it's ground on a 113 LSA, although I'm sure there are variations. Nothing odd about those cam specs at all.
Old Jan 23, 2014 | 04:02 PM
thunderstruck507's Avatar
Sounds like an older "big" grind to me. Probably work great in a stock head car.
Old Jan 23, 2014 | 09:09 PM
JWStevens's Avatar
Ok, so nobody seems to think its odd except me, has anybody actually used a came similar to this one?
Old Jan 23, 2014 | 09:15 PM
LilJayV10's Avatar
It seems you are the only one.
Old Jan 23, 2014 | 09:41 PM
JWStevens's Avatar
Lol! Well I made my point.
Old Jan 24, 2014 | 08:07 AM
There are a ton of people running this cam on the GTO Forum. Like I said, it's an Ed Curtis cam called the Tigershark. I don't know what the hell you think is odd about it. It's a pretty common 4 degree split cam, with an intake and exhaust lift that works well for stock heads, with an LSA that pretty much every other off the shelf LS1 cam has, or at least is offered in. It's not like it's a 211/243 106 LSA cam with .455 and .455 lift. Now that's odd.
Old Jan 24, 2014 | 08:47 AM
DACTARI's Avatar
Run that cam, it will be torquey as **** with lots of mid range and top end. Perfect for an F-body looking for a good DD car that will post good drag times, too. With the low lift, you can run beehives, with the added benefit of good high-rpm stability-- you can run a higher shift point.
Old Jan 24, 2014 | 08:48 AM
JWStevens's Avatar
Its not like its a unicorn or something, but I don't know anybody who has a cam that's much less than .580 lift with an .050 that high. The split is normal. I bet if I asked the same question about a cam that's 232/236 614/620 I would have a million people on here giving feedback because that's more common with that duration.
Old Jan 24, 2014 | 08:52 AM
Why are you worried about the lift? Do you have some super bad-*** heads that flow a **** ton of air that would benefit from a cam with that high of lift? The lift that cam has will shine with stock 241 or 243/799 heads.
Old Jan 24, 2014 | 09:13 AM
JWStevens's Avatar
No bad *** heads, Just a set of ported 799's which isn't the issue. Its not the lift I'm worried about. Its the combination. If the duration was 216/220 I would never have thought twice about it.
Old Jan 24, 2014 | 09:19 AM
because Lift can add virtual Duration without actual duration changes...
if the Head stalls out at .600, then most uninformed people will order a cam with lower lift and go for a duration they feel suits their needs...
but if you dont mind a more aggressive lobe profile, you can get a duration over the nose that is longer (which creates more power)with the sacrifice of spring life
the best of both worlds is to get a medium to mild profile with a longer duration and a high lift
if the head stalls out at .600 and you lift past that...you basically just created a longer time over the nose of the cam...without the grief of an extreme ramp rate to get there.
classes that have limits on what heads you can run take advantage of this and run huge lift cams to overcome the shortcomings of the head design because its not about peak lift, its about total air flow into the cylinder.
Old Jan 24, 2014 | 09:49 AM
JWStevens's Avatar
I just looked at that tiger shark cam. Its like .600 lift! Its nothing at all like my cam. That is a perfect example of what I would expect with 232/236. Geeez.....
Old Jan 24, 2014 | 10:01 AM
You say you have the cam in already, so how does it run? What kind of numbers did it put down, or what kind of ET's did it run. As long as it runs good and you are happy with it, then I wouldn't worry too much about it.
