Head Gasket for 3.908 bore
The 3.910" Cometic should work if the engine is the bigger of the two bores. You just don't want any gasket material hanging out in the fire path.
3.910 is perfect, it is .0020 over 3.908
Plus if the bore is 3.908 right now, then the piston is @ 3.904 (assuming an NA build), which means you will be fine!!
And since you know the piston is .010 out of the hole I would get a .045-.050 thickness gasket and have an optimal quench of .035-.040
Goodluck
