Picking a cam (all information included)
The car's use: street/strip more street currently than strip but I might start hitting the track more this summer.
Current "mods": SLP lid, ls6 intake, hooker headers, ORY, borla exhaust and anything else is listed in my signature
I am pretty set on going 243s as far as the heads go. I may go with PRC but it all comes down to the money aspect.
I want a cam that will have good drive ability, make good power, and not be too hard on the valve train since it will pretty much be a daily driver at least in the summer. I am really interested in the ms3 but am wondering your opinions. I think I want a Texas speed cam but am open to opinions on the heads and cam
Thanks for your time in advance
A nice mid size cam will make you much happier on the street but still allow excellent track times.
If you want to order from Texas Speed give them a call and they can help spec you something or talk about their off the shelf stuff other than the MS series. I suspect their Torquer V2 would be better suited for your needs.
The LSA will be determined by the heads. If you go with ported 243s and mill them down, you can go with a 113+2 LSA as you'll have more compression. If you keep the stock heads and lower compression, I'd do a 111+4 to help build more cranking compression. That does change the powerband a bit as well. The 111 will be choppier and peak sooner, but the 113 will drive better, carry the power a little higher, and make more power due to the extra compression and airflow of the ported heads.
Also, the head itself will help determine the profile of the cam. For example, Rise of the Phoenix has AI ported Darts which have outstanding exhaust flow qualities. Because of that a single pattern or mild split of 2-4 degrees is all his heads need to make optimum power whereas stock ported heads still probably would prefer a 4 to 8 degree split.
