Hand porting heads
Old Jan 29, 2014 | 07:07 PM
BigCityFire's Avatar
Well, the process is underway. I'm being a little conservative and trying not to push it by taking too much material.
I'll post some pics and ask some more dumb questions along the way! Giddy up!
Old Jan 31, 2014 | 10:37 AM
gMAG's Avatar
Here is the link to the YT porting. Pt#1.
Shortly, I will be doing the same.
I had previously completed the bowls & chambers, in addition to smoothing the runners.
Even a mild port behind the valves will be effective.
If you smooth the combustion chambers, compression will be reduced, slightly.
Old Feb 5, 2014 | 10:16 PM
What size cross buffs should I get to smooth the exhaust side? 1/2 or 3/4?
Old Feb 5, 2014 | 11:43 PM
xRaTeD's Avatar
crossbuff breakdown pretty quick so the bigger the better..
these are just 120 sanding roll no buff
Old Feb 6, 2014 | 06:19 AM
726.0chevelle's Avatar
13 Second Truck Club
I lightly hand ported a set of 799s last month. Mostly worked on the bowls seat area rocker hump and valve guide areas. It was my first time porting and even with a stock vj the heads picked up 10 to 12 cfm on the intake and exhaust side.
Old Feb 6, 2014 | 04:40 PM
Damn dude! I can only hope to get mine looking half that good. lol It is actually going alright. I have them roughed out, just waiting on some finishing material for the exhaust side. Still roughing out the intakes with my carbide burrs before finishing it off with 80 grit.
Old Feb 6, 2014 | 08:18 PM
xRaTeD's Avatar
Here is a photos of burr vs 80 grit I have had quite a few request to leave the ruff lately.
Old Feb 17, 2014 | 07:39 PM
Well I had my heads flow tested. It went really well, surprisingly! I kept it safe and didn't get super aggressive with them. Turns out they are flowing:
.500 Intake 287cfm, exhaust 201cfm
.600 Intake 298cfm, exhaust 210cfm
I forgot to take the damn sheet home with me, so I don't have the exact numbers down to the decimal.
One thing the machinist suggested, was taking more out of the bottom of the intake floor. When I did this the numbers went way up above .500 lift. before that they were nose diving a lot when approaching .600. Hopefully I'll see some good rwhp numbers as a result. Thanks to all who helped!
