Another what cam thread. Lq4 and 243's
I've got an lq4 with 104k and a set of 243's with ~50k miles off a member here. Otherwise it's stock.
Vehicle is a jeep tj at around or under 5k lbs. nv4500 manual transmission and a set of block hugger headers. Keeping it n/a also.
Going to be taken off road but I'm not sure I should put emphasis on low end torque, meaning not sure if it will make a difference, as I'm used to the factory 4 cylinder and a massive 120 lbs of torque.
Would like to be around 400 rwhp ( just cause no real reason for needing)
A few questions. Should I mill the heads? If so how much and should I use a stock head gasket? I need to use pump gas not sure if it matter but here I only have 91 and I'm 1000 ft altitude. And I need it drivable. I would like to take it to Colorado and be capable at 10k feet.
Anything else besides a tune I should get? Supporting accessories etc?
Brian's also the go-to guy for quality valvesprings/push rods....
Havent been to the dyno since things have been fixed but its night and day since then.
I'd personally leave the heads alone as you can't gain much without losing a lot of P to V and you have 91 octane. You could mill up to .020 with the cam I'd recommend and possibly gain 10-12rwhp, maybe 15rwhp when the cam is added.
Jeeps being pretty light weight vehicles, I'd recommend this camshaft:
229/232 .615/.575 112lsa
I'll be running either 37's or 40's. And probably 4.88 gears.
I'll be using an ecm.
