LQ9 build in Avalanche
Old Jan 28, 2014 | 09:54 AM
Thunder85's Avatar
Default LQ9 build in Avalanche
My 5.3 lost compression in my 04 Avalanche, so I am replacing it with a LQ9 6.0. I want to beef it up before I install it. I was looking at the Lingenfelter
GT2-3 cam and valve spring kit. Any thoughts on this kit, and what else I can do to add more power without killing relaibility? This will be a daily driver, but I have a work truck so it won't be racking up the miles. Any recommendations on exhaust? Anything helps, thank you!
Hopefully... future badace Avalanche!
Old Jan 28, 2014 | 10:01 AM
Baconz28's Avatar
I would consider one of those towmax cams. valve springs I would do btr.
Old Jan 28, 2014 | 10:52 AM
ATK Engines's Avatar
The 6.0 with a cam swap and a set of headers is easily good for 450+HP which is a big upgrade over a stock 5.3 and this is reliable power.
Your transmission will be the weak link, they are notorious for going out with this swap. If you are going used, get the trans/controller that came out of the truck as well. Get with a good tuner here on the forums...it will make all the difference.
Old Jan 28, 2014 | 11:58 AM
Thunder85's Avatar
Thank you for the input. My mechanic is worried about the transmission as well. What upgrades can I do to the transmission to help?
Old Jan 28, 2014 | 11:59 AM
Thunder85's Avatar
Anybody have any suggestions on good tuners in the Tulsa area?
