Morel lifter failure
Old Jan 31, 2014 | 07:53 AM
SIG-054's Avatar
Default Morel lifter failure
Had a morel 'street' lifter fail in my head/cammed ls1. 12,000km since I done it all. Noticed a loud clacking noise as I pulled into my driveway on a warm afternoon. Pulled the cover off to find excessive play in one of my Jesel rockers..
Started pulling it down to find a chunk in my valley. It's been super hot whilst rubbing on my cam exhaust lobe...
I dare say my lifter bore will be damaged and needle bearings in my engine.
Wish I never cheaped out on these lifters.
Old Jan 31, 2014 | 08:01 AM
ATK Engines's Avatar
With that cam and spring pressures needed, definitley should not have went with the Street lifters. Hopefully it isnt to much of a mess.
Old Jan 31, 2014 | 08:05 AM
SIG-054's Avatar
I have K Motion K800 springs, didn't think it was too excessive.
Old Jan 31, 2014 | 08:10 AM
SIG-054's Avatar
Bought a new one in hope that it would be an easy fix from Njclsx in Melbourne.
Still yet to pull the head yet, been busy and really hot weather.
Old Jan 31, 2014 | 08:26 AM
The Street lifters are meant for cams under 230 Duration at .050" and under .550 lift with the .700" wheel design, per Ed Morel himself.
Old Jan 31, 2014 | 08:30 AM
SIG-054's Avatar
So they are no where near as good as ls7's or even the stock ls1 lifter then?
Old Jan 31, 2014 | 08:54 AM
mchicia1's Avatar
I have always been skeptical of these considering the manufacturer only lists a max rpm of 6200-6500.
These are the Lunati equivalents. I wonder where these are made. I would put money down that some parts are outsourced.
http://www.lunatipower.com/Product.aspx?id=2536&gid=380
Old Jan 31, 2014 | 09:05 AM
JakeFusion's Avatar
Super Hulk Smash
I'd definitely step up to the 5206s or go with Johnson Short-Travel lifters... the ones I have are good to 900lbs spring pressure... with a .700" wheel. The axle retainers are beefier on the .700" wheel vs the .750" wheel in an .842" body. At least with the Johnson vs the Morel.
But either has heat-treated, hardened billet steel body. So hopefully they won't come apart like the street series did.
Old Jan 31, 2014 | 09:56 AM
SIG-054's Avatar
The one thing I did notice when I bought and installed these was this particular lifter that failed didn't feel quite right. We made note of this. It wasn't as 'spongey' as all the others, felt heaps firmer. Don't know if that contributed to the failure.
I've done a whole year of daily driving with these in the engine, done about 30-40 passes at the strip. No signs of noises, perfect preload etc.
I just thought these would be a little better than LS7's, I know quite a few guys with far more aggressive set ups than mine that run them with absolutely no drama.
Tbh I don't know what to do next, just yet
Old Jan 31, 2014 | 02:19 PM
soundengineer's Avatar
But either has heat-treated billet aluminum body. So hopefully they won't come apart like the street series did.
the 5206's have been replaced by the 5274...
same lifter, slightly different link bar design so it clears warhawk blocks...
I've run 5206's for years with no issues with pretty extreme cams and more spring pressure than most LS guys even think about using..LOL
Old Jan 31, 2014 | 02:22 PM
JakeFusion's Avatar
Super Hulk Smash
That's right the 5274 clears the Warhawk block.
Brian Tooley still sells the 5206s.
Old Jan 31, 2014 | 02:26 PM
they are listed....
but he sends 5274....
theres no price difference, and they fit all blocks (not just the warhawk)
I just ordered some back in october for my build
ordered 5206's.... 5274's are what showed up
Old Jan 31, 2014 | 03:25 PM
Brian Tooley Racing's Avatar
Originally Posted by soundengineer
they are listed....
After some complaints we started carrying the 5206 again. We were trying to cover all applications with the bent link bar 5274's but some guys REALLY wanted the straight bar.
If you have the 5274 and would prefer the 5206 you can send them back and we'll swap them out.
Thanks
Old Jan 31, 2014 | 05:07 PM
Jase01's Avatar
Another Australian here, not intending to hijack but this is quite a timely thread as I'm about to purchase lifters for a rebuild and was recently made aware of these Morels. My intended application is daily driver and less aggressive than this particular camshaft (222/224 .560" 112 LSA at biggest using AFR standard application PAC springs) but my strong preference is to ditch the standard trays and use link bar type lifters.
I was intending to use Comp 8957-16 standard travel link bars and was advised by one parts supplier that they are aware of some failures with them but they supply plenty of Morel 5290's with no known problems and they're cheaper. I don't intend to rpm over low to mid sixes absolute maximum (won't need to) will be using YT roller rockers and the spring pressure, camshaft duration and ramp rate will be fairly conservative in my case but I would prefer to spend more and err on the side of caution with components and have reliability and a very long engine life. I would appreciate some experienced thoughts on the Comp lifters or the better model full travel Morels, thanks in advance.
Jason.
Old Jan 31, 2014 | 05:36 PM
Gray86hatch's Avatar
The Morel are not alum body.
I ran the street lifters with no issues 4000 miles shifted at 7500. 240-250 .620
I have the high rpm now and the visual I just did on them they looked like new.
Over rev, rev limiter or out of control valve train will kill any parts.
Been there done that on a 10'000 rpm n/a 10.5 engine
Old Jan 31, 2014 | 05:49 PM
JakeFusion's Avatar
Super Hulk Smash
You're right. I said billet aluminum. It's a hardened billet steel body.
LS7 lifters are cast.
I have no idea what the street Morels are.
Old Feb 1, 2014 | 11:18 AM
dirtbag's Avatar
Never cheap out on lifters. I run Morel 5206's no problems, and they've seen some abuse.
Not to knock LS7's, I just don't understand why someone would risk it. Spend $350 more on lifters or spend $3000 more on rebuilding a short block. You make the call lol.
Old Feb 3, 2014 | 07:02 AM
SIG-054's Avatar
Well, the tie bar broke and turned both lifters in the bores. Can't even get the exhaust lifter out. Great
Old Feb 3, 2014 | 09:45 AM
JakeFusion's Avatar
Super Hulk Smash
That sucks.
Old Feb 3, 2014 | 11:26 AM
vettenuts's Avatar
I would also be very careful on pushrods. With a setup like this and 5/16" pushrods will flex and wreak havoc on the rockers and lifters.
