Issues with LS1.
Old Feb 1, 2014 | 09:48 PM
55chevy's Avatar
Default Issues with LS1.
2001 LS1 with 16K miles. Stage II Patriot heads. Baby Cam.
The first is a problem is with cylinder 4. The plug looks bad and is oily even on the electrode. When I take the plug out and turn the engine over, I can see that it is firing. I'm not getting any obd codes.
-I've swapped the plug, plug wire, coil, and injector and the issue stayed with that cylinder.
-I checked the coil input with a noid light and it flashes like the others.
-I've done a warm leakdown test and all cylinders look good with a range of 4 - 7 % leakage. This one had 7%.
-I did a compression test and this cylinder had a 198 psi and all of the rest were in a range of 185 to 205.
I'm going ahead and mentioning the 2nd problem just in case it's related.
I've had this 2nd problem for a while but didn't realize it was that bad until I did the leakdown test. The car has been using about 1 quart of oil every 1000 miles and smoking from time to time. While doing the leakdown test, I found what appears to be a lot of milky oil in my intake. I haven't removed the intake yet but when I was turning the engine with low air pressure to find TDC on one of the cylinders, I heard fluid gurgling in the intake and then some milky oil/water flowed out of the throttle body.
So to try and fix the oil usage, I'll be doing the LS1 to LS6 PCV conversion and changing the valley cover to an '04 or later cover. I'm also thinking of adding a good catch can.
2 Questions...
-- What is my next step in trouble shooting cylinder 4?
-- I know this sounds crazy but could the oil accumulation be bad enough in the intake that it could be affecting cylinder 4? The reason I ask is because it was cylinder 4 that I was putting on TDC when I heard the gurgling in the intake.
Old Feb 1, 2014 | 10:29 PM
conan's Avatar
The PCV is the first place I would start since the compression check and leak down didn't tell a bad tale. Valve seals could be another culprit, possibly oil scraper rings ??? When I rebuilt my LM7 most of the oil scraper rings had no "spring" left in them and were stuck in to the ring land... (219,xxx miles)
Old Feb 1, 2014 | 11:28 PM
one fast zo6's Avatar
Sealant on rocker arm bolts,(needed for ported heads), PVC system, Valve seals could be another problem.
Old Feb 2, 2014 | 07:56 AM
55chevy's Avatar
Thanks for the 2 responses...
Any idea about the one plug being oily? The other plugs look pretty good.
Old Feb 2, 2014 | 08:46 AM
55chevy's Avatar
Could the cylinders be washed out and still have these leakdown and compressioin test results?
Reason I ask, I've always thought my car was tuned too rich. I plan to get it checked when I get the repairs made.
Old Feb 3, 2014 | 09:57 AM
lmt0705's Avatar
Has The Motor Been Rebuilt? Is It Possible Someone Installed Rings backwards?
Old Feb 3, 2014 | 11:37 AM
55chevy's Avatar
I don't think the shortblock has been rebuilt. I got it when it had 1200 miles on it and put the heads on and the cam in before I ran it. I've got the ls6 valley cover and oil seals ordered so I'm going to replace them first.
I still don't know why the spark plug in #4 cylinder is wet with oil after running about 15 minutes. Just wondering if that cylinder has so much oil that it won't fire. The leakdown and compression test seem to be ok.
Thanks for responding.
Steve
Old Feb 3, 2014 | 11:56 AM
Archer51's Avatar
Default Does an ls1 engine have reliability issues?
Im coming from a horrible lt1 and i dont want to buy another pain will i face ignition issues with an ls1? Will it leave me stranded like my lt1 did? What would cause an ls1 to leave.me.stranded? Need some imput thanks.
Old Feb 3, 2014 | 12:03 PM
97camaro383's Avatar
No, the ls1 engine is really reliable. If you keep up with maintenance and don't try to destroy the motor on a daily basis then it'll last. What kind of opti were you putting on the lt1? I had problems with my opti always taking a **** on my lt1 and then I bought a decent accel opti and used it on multiple cars with no issues. The cheap a1cardone & autozone optisparks just fail and cause headaches.
Old Feb 9, 2014 | 08:18 PM
55chevy's Avatar
I'm making progress. I got my new LS6 valley cover installed and I will be completing the pcv conversion when I put the manifold back on.
For cylinder 4, I found about a 1/2 teaspoon of oil sitting on top of the intake valve when I pulled the manifold off. So, I got new valve seals and have them installed. I also, put high temp sealant on the rocker bolts and I'm letting it cure for 72 hours like the Permatex package suggest. I can hardly believe that much oil is getting through the threads and seal but I'm giving it a try. If this doesn't work, I guess I will be pulling the head off to see if it's cracked or something.
I purchased the Tim's valve spring tool and it worked great.
Thanks for all of the input so far. If you have any other ideas on how the oil is getting on top of the valve, let me know.
Steve
Old Feb 9, 2014 | 09:54 PM
A.R. Shale Targa's Avatar
Possible bad valveguide allowing too much oil on intake stroke ????
Old Feb 10, 2014 | 05:58 AM
55chevy's Avatar
Thanks. I don't guess there's anyway to tell without pulling the head.
After the sealer cures, I'll spin the engine with the starter before I put the manifold on and see if I see any oil accumulating. If I do, I'll pull the head.
