Does anyone know the torque spec's for the rocker
studs that come with the kit? It is not specified in the instructions. I realize that the stock spec is 22lb. for the stock rocker
bolts, so if someone responds with an answer of 22lb. I will probably
! I have always torqued my rocker studs on early small block Chevy aluminum heads to 60lb. but wonder if that is too much for the small 8mm. bottom half of the 3/8" studs? I would hate to break one off in my pretty PRC 237 heads. Any help will be appreciated. THANKS!
