Smashed intake valve seals
Old Jan 9, 2015 | 09:40 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Just thought I'd leave this here...
(YOUR lift) + .050 (clearance from coil bind) = "x" + the spring's coil bind = optimal install height Hope that helps even a little bit. I'm not even TOUCHING what was said before.
Old Jan 10, 2015 | 10:42 AM
TurboBuick6's Avatar
(YOUR lift) + .050 (clearance from coil bind) = "x" + the spring's coil bind = optimal install height.
This is actually not true. I run .150 from bind with no issues. Some setups are optimal less than .040 some are optimal at over .150. There is no one rule for every engine on earth.
Old Jan 10, 2015 | 11:55 AM
jmargo's Avatar
I ran into this problem a bit back. I have not pulled the VC in about 1k miles but I need to.
https://ls1tech.com/forums/generatio...-unseated.html
Old Jan 10, 2015 | 01:44 PM
dr_whigham's Avatar
The Scammer Hammer
Well it's what I do, and what I've been taught. I also never had a cam with soft lobes either, so that's more reason for myself.
Old Jan 11, 2015 | 02:51 PM
Brian Tooley Racing's Avatar
Patriot and BTR.
Originally Posted by Jason 98 TA
Btr springs are the associated spring patriot sold. He can sell you a new set of springs that will drop right in.
The heat treat equipment and heat treat process that our springs utilize is new within the last 3 years, and isn't anything that Patriot ever sold or used.
You guys look desperate when you try to say our springs are the same, because I think you both know they are not.
Old Jan 11, 2015 | 03:10 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Brian don't get offended I mean they're the same manufacturer and will interchange. Don't get so but hurt, I even recommended he contact you. Lol
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 11, 2015 | 03:39 PM
I updated my response Brian to better clarify.
__________________
Jason
2005 Twin Turbo C6
